Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon IXY Digital 10.0 Mega Pixels
My camera will not turn on, even after I changed to my backup battery. I plugged it in to my computer and I still get no power at all.
  • 21 Answers
Take out the memory card and check if its working.Replace the batteries.connect it to the computer and check its turning ON.If not your camera has gone for a toss........sorry about that.
Posted on Sep 07, 2008
Where is the backup battery located and how can I change it?
If there is a backup battery then in most cases it will be soldered to the main formatter board, which is the board that the usb or network cable plugs into. In most cases with this product that battery will be soldered to the main board. These are often rechargeable batteries and the printer needs to be connected to AC power for at least 12 hours to charge it.
Oct 01, 2015 | HP Officejet Pro L7650 Printer
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Not Working During Power Outage
    Bad battery in the UPS. To test unplug all equipment. Check outgoing power with voltage meter. Should read around 115vAC. Then unplug from the wall outlet. Check voltage again. If no voltage is present its a bad battery.
    Sep 04, 2013 | CyberPower Computers & Internet
    Apc bf250 will not power on
    Did you charge the batteries before installing them?
    Jun 27, 2017 | APC Back-UPS Office 250VA (BF250) UPS...
    My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
    Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
    Feb 08, 2012 | Konica Minolta Cameras
    My polaroid DVF-720 digital camcorder wont turn on.the battery is fully charged and it is in the right way.
    1.Remove battery
    2.Remove memory(EXTERNAL MEMORY)
    3.Plug in the power ,CLICK BUTTON ON in 10 second.
    4.Plug out the power
    5.Insert back battery.
    6.Click button ON IN 10 SECONDS AGAIN.if it will ON MOVE TO STEP 7. IF NOT,GO TO STEP
    7.OFF CAMERA AND THEN BACKUP YOUR MEMORY(EXTERNAL) to pc
    8.CHECK AND FORMAT
    9.INSERT BACK EXTERNAL MEMORY
    10. ON BACK AGAIN.
    11.TRY CHANGE BATTERY . SOMETIMES BATTERY WAS ISSUED FOR THAT. IT NEED OPTIMUM POWER. BATTERY FULL DOESN'T MEAN THAT IS OKAY.
    however, mostly issue are cause from external memory, if that can ON without external memory that mean your memory was problem. backup, checking disk.
    FORMAT, USING PC .IF SUCCESS IN FORMAT USING PC, THEN FORMAT AGAIN IN YOUR CAMERA. IN FORMATTING USING PC, TRY USE FAT32 THAN FAT.
    TRY IT...out
    May 28, 2011 | Cameras
    Apc surge protector and battery backups
    you have to have the power rating rated in amps of the bed...if the rating of your bed and the system are same or even less than that..(i.e. the rating of television is less than that of computer monitor,so u can connect tv for long time than monitor when power goes off ) then u can surely use it.....but it ll provide the supply only till the back up is stored in the battery,when the power goes off
    Jan 05, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
    APC Smart-UPS 1000VA is powered on but not working
    Try turning the unit off for a little while, unplug it from the source even. afer about 5 minutes plug it back in and try it again. You may have a bad battery, how old is the unit. UPS batteries should be changed out every 3 year's, max every 5 year's if you want good reliability. At 5 years you are taking a chance.
    Jan 18, 2007 | APC Smart-UPS 1000VA UPS System
    Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
    193 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
