Question about Nikon Cameras
Hi i am using a Nikon N75 to take pictures for my photo class, and the instructor wants us to take low light indoor phtotos at a shutter speed of 1/30 at f2.2. However, when i go to set these settings in manual mode the camera will not let me set my aperture to 2.2 it usually stops at 4 and there is no way i can make it 2.2. i didn't know if there is a limitation on the camera but it seems like i should be able to select what i want.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
It's probably a limitation of your lens. You didn't say what lens you're using, but one of the common kit lenses sold with the N75 only goes to f/3.3 at best. If you had a lens that opens up more, the camera will let you use it.
The difference between f/2.2 and f/4 is about two stops, so to compensate you'd have to use a shutter speed of 1/8.
Posted on Dec 30, 2009
I would like to know if a 24mm Nikon f2.8 Ai Manual Focus Lens will work on a Nikon N75 SLR Camera
Yes and no. It will fit and you can take pictures with it. You'll have to focus manually, of course, and you won't get any exposure help from the camera's light meter. You'll have to use the camera in the Manual exposure mode, setting the shutter speed on the camera body and the aperture by turning the ring on the lens and, as I said earlier, without any help from the camera's light meter.
Mar 17, 2012 | Nikon N75 35mm SLR Camera
My husband pulls tractors at night at tractor pulls, everytime I try to get a picture its too dark, the lighting around the pull isn't the greatest but it has some light
There are several solutions to taking pictures in the dark or low light. Night time photography can be difficult without a tripod. There are three ways you can get a brighter photo
1. Larger aperture - Make sure the aperture is set to the lowest f-stop for the largest aperture. f/2.8 or f/5.6 depending on your lenses capabilities. Choose the lowest number
2. Longer shutter speed - A longer shutter speed will allow more light to hit the canera's sensor and create a brighter picture. Unfortunately with a longer shutter speed, you will probably need a tripod because the photo will come out motion-blurred otherwise.
3. Higher ISO - A higher ISO will make the camera's sensor more sensitive to light and therefore creating a brighter picture without having to have a longer shutter speed. High ISO, however, can introduce unpleasant noise/grain to a photo.
If you want to take your picture while holding the camera in your hands, I recommend the largest aperture (small f/stop) and a high ISO.
If you have a tripod, use it! and use a longer shutter speed since the tripod will hold the camera steady for you.
Jul 09, 2011 | Nikon Cameras
I have trouble taking indoor (low light) photos. pictures come out blury and the camera does not snap the picture properly i have a nikon 35 mm n6006 camera
Hi Rebecca--
The hardest thing about low light photography is balancing your available shutter speed to the amount of action you're trying to capture.
Here are a few things to try:
1) Try using a tripod. Steadying your camera during long exposures will greatly improve your image clarity.
2) Buy a faster film. You may need to increase your film's ISO setting. Try 400 to start, then go up from there. Remember, faster film always produces grainy images, and it usually costs a little more to process. If you're stuck with 100 ISO, you can always "push process" the film, where a given ISO is let to sit in its developer longer than usual--This will cost you more too!
3) Invest in a good flash system. Nikon has tons of hotshoe flash systems that rarely compromise the ambient light-mood of a given situation. Look for one that lets you aim the flash in different directions, and try to find one that will meter a light situation on its own.
4) Turn on the lights. If you're ok with losing some of the romance of an image, turn on some more lights to give you some more flexibility when making your exposure choices.
5) Open up your aperture. You may find that a lot less in depth of field will give you a lot more in image clarity and exposure flexibility. Shooting at f2.8 with only a birthday cake lighting your subject will grant you many more valuable shutter stops that shooting the same with f5.6.
Remember, Rebecca, if you're shooting handheld, you must do everything in your power to shoot with the quickest shutter speed available. This will cut down on the blurriness of your indoor images.
--Hope this helps.
Oct 06, 2010 | Nikon N6006 35mm SLR Camera
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
Without flash
Although your eyes can adapt to see well in low light, the camera needs a lot more light to take good photos than your eye needs to see in low light. Taking photos of a play or other indoor performance is a very difficult situation.
1) You need a fast lens, one that shoots at aperture f/2.8 or faster (i.e. f/2.0, f/1.8, or f/1.4). Your 18-55 lens is f/3.5-5.6, which is not a fast lens. When you zoom to 55mm, you can only shoot at f/5.6 which is 1/4 the light gathered at f/2.8, so the shutter speed needs to be 4 times longer, which means 4 times slower.
2) Set the camera to use the highest ISO it offers. Look in your manual for instructions on how to change the ISO. Don't forget to set it back when you are done!
3) Use the shooting mode that lets you specify the aperture. The camera will select the shutter. I'm not familar with the mode name for Nikon cameras - for a Canon camera this is the AV mode (for Aperture Value).
4) You may want to dial in some -EV - this means a "minus" value in the Exposure Compensation. I usually set this to -1/2 or -1 for low light shots. The photos come out just a tiny bit darker than normal, but the trade-off is that I get a faster shutter speed.
5) Even with all the settings above, the shutter speed is likely to still be quite slow. You must hold the camera very still. A monopod or tripod is usually necessary. In addition it helps if your lens has VR (vibration reduction) to minimize camera shake. Finally, no matter how still you hold the camera, if the subject is moving then the image will be blurry. So only shoot when the subject (person on stage) is relatively still.
If you don't have your camera manual let me know, and I'll look for it online and give you a link to the pages that detail the settings you need to change.
Dec 28, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 shutter speed problem
The D40 will not take great photos of an indoor event without blurring or noise. You need a fast lens and a high ISO using the popup flash or on camera flash would be ideal but some of these events you can not use flash. All these images I shot with a Nikon D40. http://www.facebook.com/home.php?src=fftb#/pages/Keller-TX/Raving-Design/78762448229?v=photos&ref=ts Learn to use the camera for ur events. Experiment it's all about trial and error. Ray
Dec 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
How do i take photos indoors/ what settings do i use?
alexisalejan,
well first how far away from the stage will you be?
will you be using available light or a flash unit?
shutter speed and f-stop depend on the light source and film speed. (iso )
the faster the film the less you have to use flash, the lower the f-stop the less depth of field you have, the kind of flash is important, most flash units are good for only around 20 ft.
i would use a high speed film and not use flash. flash will kill any colored lights. try to keep the f-stop at least f/8 and the shutter speed no less than 1/60 sec. have fun.
Dec 13, 2008 | Nikon F60 35mm SLR Camera
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Shooting in dim light with Sony T1
The T1 has the weakest flash of any digital camera. It is only rated for 4.9 feet coverage. So it is natural to want to try some low light techniques. But the T1 is also a point-and-shoot camera, with some scene modes. That means you have little control over low light situations. Under low light situations, it is best to use a tripod. But the T1 does not have a tripod socket. You want to set the shutter speed to a very low speed, the aperture to wide open and set the ISO to its highest setting. But the T1 will not let you control those adjustments. You can try the "Twilight" or "Twilight Portait" scene modes, and also set the Exposure Compensation to +2. Also set the flash to "off". Cross your fingers and fire away, even if the camera warns you there is not enough light. A dark picture is better than no picture. Sometimes you can "pump" it up with software.
Sep 08, 2005 | Sony Cyber-Shot DSC-T1 Digital Camera
Cameras Logo
41 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
