Xerox phaser 8550 get error code 07,010.43:20720
  • Anonymous Apr 22, 2009
    My Phaser 8550
    got error code 07, 007,40 : 12493
    What would I Do?
    President:
  • 2,072 Answers
That is a print head tilt or axis failure.
There are 2 problems that cause that 95 percent of the time.
1 is a stainless steel pivot block on the left side frame that gets filled with overflow ink. Needs cleaned.
2. The print head wiper blade is stuck to the print head due to shuting it down improperly or a power failure.
Posted on Aug 20, 2008
2 Suggested Answers
SOURCE:
  • 57 Answers
SOURCE: xerox phaser 8560 DX error
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Posted on Jan 19, 2011
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
XEROX CODE 02-540
02 errors usually refer to configuration card issues. I couldn't find anything on the 540 can you verify that's the complete error code.
Mar 03, 2014 | Xerox PHASER 8550 COLOR Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8550 . what does printer error code 09,005.40:78005 mean?
9,0XX.xx Errors - Ink Loader Faults. Try switching the ink loader.
Jul 08, 2009 | Xerox Phaser 8550/DP Thermal Printer
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
Error code in Phaser 8550 window. ?:07,010.43:1362
The exact explanation per xerox is " The Printhead is stuck in the tilted position, and is not able to tile forward to the print position, due to problems.
This is usually caused by broken printhead restraints, of the machine got shut off in the middle of warming up, and the printhead is stuck to the cap wipe assembly.
Regardless the machines covers will have to be taken off to go any further.
Mar 15, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
Error code for 8550
Call Xerox, they have a problem with this code and the ink loader needs to be updated.
It has to do with the yellow sicks loading properly
Oct 31, 2007 | Xerox Phaser 8550DX Laser Printer
499 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
