Question about Curtis-Mathis CM27101S TV
No remote i want to able to program the tv without the remote it only gives you the ant channels
  • Anonymous Nov 28, 2008
    We are upgrading our dish to HDTV. We have an old Curtis Mathis TV. The Dish Network Technician says we need the remote so he can reset the TV. Apparently it must read "video" on the screen before he can reprogram the tv. Originally, when we subscribed to dish network, the technician put in a code and was able to program the tv. We would like to know how we can reprogram the tv for hdtv without the remote.
    Hope you can help.
    Note: We are getting a new wide screen tv, but would like to put the old Curtis Mathis in the bedroom for the children.
  • 25 Answers
Try buying an universal remot control. It may work
Posted on Aug 20, 2008
SOURCE:
Can get only 1 channel to program on my toshiba
hi if the tv has dtv just select air digital only thanks
shaun
Mar 25, 2017 | Toshiba 40RV525U 40 in. LCD TV
Is there any way to get into menu to change from "ant" to "cable" without remote? TV does not have original remote and universal remotes will not access menu options.
Hold volume -/+ few seconds, menu will appear. Navigate up/down menu with channel buttons, page change with volume buttons.
Jan 21, 2014 | Sansui DTV3200 32" TV
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Can you change channels on tv's without remote
Hello
If your tV has a Menu Button and channel up-down, programme up-down button at tis front control panel, you can change channels and other inputs using these buttons. You haven't give any details of your tV, its Brand Name, Model Number etc, so I can give you this much detalils only to you.
Nov 25, 2011 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How to program channel without remote
First be aware that if you are using an antenna this television has an analog tuner which is no longer capable of receiving any digital signals which is the only channels being broadcast as of June 2009. If you have a cable or satellite receiver then here is the procedure for auto programing your channels. Make sure your active cable/satellite is plugged into Ant 1 (Antenna 1) on the back of your set.
On the front panel push the menu button until the "Channel" is highlighted. Then push either the plus button or the down button to highlight auto program.
Once that is done push plus or up and the set will automatically tune in all the available stations
Zashiban
Jun 04, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Digital converter box worked with RCA analog TV and outside antenna. Had to unplug both for some work in house; when we plugged everything back in, there is no digital input. I checked everything over many...
Make sure you have an ANT. connected to the INPUT on digital converter box....then OUTPUT that signal to the INPUT of your TV....put TV on channel 3 or 4 or put TV on VIDEO if using red, white and yellow wires...power up and program converter box for channels....should work... if not try a set of rabbit ears instead of outside ant.
May 19, 2010 | Televison & Video
Trying to hook up the tv to direct tv, don't have remote and cannot get tv on to channel 3
The only work around you have without a remote is sloppy. If you are patient, give it a go: connect the box to the TV (cable/ant input), turn on the direct TV box, using the TV button panel (here comes the sloppy) fumble your way to the auto-program menu, start auto program. When the auto-program is done, you will have just CH 3 memorized, so the CH -/+ button will only go to that channel. Worst part will be figuring out the buttons on the TV... it can be frustrating. It may take a few tries, that's why I call it sloppy. I hope this was useful, best wishes.
Apr 19, 2010 | Insignia NS-24 TV TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Curtis-Mathis CM27101S TV Logo
87 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Vitally Alcher
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
