Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Grinder does not work!
When i turn the machine on and try to grind up some coffee beans, the machine makes a sound like the motor is trying to grind. when i open up the grinder lid, i can see that the grinder is spinning but nothing is getting ground. then the sound will stop and the screen will say "Grinder empty, ready for use" but the grinder has plenty of coffee beans in it. how do i fix this problem?
  • 3 more comments
  • jkovacs Aug 22, 2008
    I have taken my Saeco Italia Sup021 apart to inspect the grinder but after reassembly I'm getting a red flashing malfunction warning indicating the grinder motor is blocked, or dispensing unit motor is shutdown. Does anyone know if there are grinder alignment photod details available and or diagrams? Or is there a button combination sequence that will reset the coffee machine?
  • Anonymous Dec 02, 2008
    Grinder does not pull beans down.
  • Anonymous Dec 26, 2008
    I have the same grinder problem.  I just purchased my Saeco 'refurbished' model, and am attempting to make my first cup...but no go.
  • Anonymous Jan 03, 2009
    My husband and I have the same problem. Has anyone come up with an answer?
    Crabby Without Coffee
  • Anonymous Mar 12, 2014
    Grinder mechanism won't pull out
  • golvnot Apr 12, 2009
    The link above shows how to disassemble the grinder for cleaning and doser chute cleaning.
    My housekeeper poured water down my coffee bean resevoir and the water mixed with the existing coffee grounds in the chute and clogged the thing up. Once it got clogged the grinder appeared to stop working, but in reality the grinder worked fine there was just no place for the grounds to go, so there you go.... Maybe water caused your problem too??
  • 515 Answers
Make sure you not get any damp into the grinder.
Posted on Aug 20, 2008
My Saeco Odea Go coffee machine grinder screw rotates with on beans but does not rotate when beans are added. Motor sounds like its working.
There are different possibilities for your problem. First the motor might be damaged and is more weak than before that is why is stop when it need to grind beans. In this case only with replacement motor can solve the problem.
Second probably due to long use of oily coffee or low quality coffee beans or other reason there are coffee grounded in the grinder that become like rubber and does not leave the new coffee to pass through grinding burrs. For this either you have to dismantle the whole grinder and its burrs and clean them with brush or you can use a new magic product that you can fin in eBay it can clean automatically the grinder in 30 second see it at the link
http://www.ebay.com/itm/PULY-GRIND-COFFEE-GRINDER-CLEANER-CRYSTALS-20-GRAMS-PACK-OF-3-PACKETS-/131031511160?ssPageName=STRK:MESE:IT
You can try the above fist and you may solve the problem in minutes if not then you can proceed with the replacement of the ginder burrs or motor.
Jan 10, 2015 | Saeco Odea Go
Grinder blocked Saeco Caffe Charisma
If the problem is only just stuck then you should try to rutn the gringing adjustment to more gross grinding and first try to remove all remain coffee beans from grinder, with the use of avacuum cleaner try to clean everything from the grinder beans and grined coffee. Then try to make a coffee if it continue to be stuck turn for more gross coffee grinding clean with vacuum and try again is the grinder is only stuck then this will work if after all these the grinder does not turn then you will need to remove it and also you might need to replace it.
May 10, 2012 | Saeco Caffe Charisma Espresso Machine
Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle. Seems like something is stuck in the grinder.
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Breville BES860XL
Attemps to gind but no beans seem to get through Then the display indicates 'add beans' although it is full
Machine thinks there are no beans because it is not grinding. Most likely the grinder is blocked. The common causes are a small foreign object, a stale hard bean and moisture (either from water spillage or moist beans). The first thing you should do is vacuum ALL the beans out, set it to the coarsest grind setting and run the grinder a few times ( with no beans). Then put a small amount of fresh beans (make sure they are dry and not from fridge or freezer) in and try again. Give it a few goes. If it still wont grind have a good look down there, if it looks wet let it dry out for a while and try again. If none of thes easy tips help you will have to remove the top grinder burr and clean both burrs. Good luck.
Dec 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Does not grind beans
This can be caused from a broken by a brken grinder motor or even broken grinder sensor.
However this can be cased by a stuck grinder from grinded coffee to the grinder bledes. So you try from the last posible problem by removing all the coffee beans from the machine and by the use of a vacum cleaner try to **** all the remainings both beans and grinded coffee. If you can remove the top panel then you will have access more direct to the grinder and by the use of painting brush and vacum cleaner you will be able to clean the grinding blades mere intesive. Try to rotate the blade manualy to be sure that they can run after the cleaning.
So now you will be able to add some beans and try the machine again. If the probelm remains then you will need a new motor.
Good luck.
Please emeber to vote for this answer
Mar 13, 2010 | Saeco Easy Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 21, 2009 | Gaggia Paros Espresso Machine
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jul 24, 2009 | Gaggia Syncrony Espresso Machine
When i turn the machine on and try to grind up some coffee beans, the machine makes a sound like the motor is trying to grind. when i open up the grinder lid, i can see that the grinder is spinning but...
Generally, coffee beans are oily and form a goo in these machines.  You may get lucky by first unplugging the machine, getting some copper wire (#14 or #12) and poking around in there to loosen the crud up.  If this doesn't work, the unit will have to be disassembled and cleaned.  Messy!
Nov 26, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
561 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
