Question about Estate TGDS840JQ Gas Dryer
Dryer is not drying correctly
The dryer drum works, and i replaced the fuse, but it takes a long time to dry the clothes. I have stopped it to see if the heat is there sometimes it is some times it is not. I use it mostly on low setting but tried the high setting same problem it takes about 140 to 210 min. to dry the clothes. I use it every day at least for 3 or 4 loads. now it is getting harder to keep up with the laundry please help.
    Genius:
  • 1,028 Answers
Ck vent system to outside ck for crimped vent hose on back or plugged vent to outside ..if burner ignites but fails or is slow to reignite suspect the coils on burner (the 2 black things with wires attached)
Posted on Aug 20, 2008
SOURCE:
What setting for drying clothes takes the shorties time
make sure your filters and around your drum is clean that is a reason for clothes taking long to dry
Oct 13, 2014 | Dryers
Fridgidaire Dryer not drying completely
Good Morning David, thank you for allowing me to assist you!
I understand your dryer is experiencing lack of heat. There are several factors that could cause this; some of which you can check prior to scheduling a professional.
Have you checked your lint filter recently? I ask because if a lint filter is full of lint it will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder area after each and every use. Check the lint filter for any buildup of fabric softener that will also restrict airflow and wash with soapy water to clean. If the filter is damaged then it will need to be replaced.
Additionally to checking the lint trap area, please investigate the ventilation (duct work) system connecting to your dryer. Often we forget to clean this duct work therefore over time debris can restrict air flow. Check the air flow by disconnecting the accordion-like duct work from the dryer appliance. Run a drying cycle, with clothes inside the unit, but keeping the duct work disconnected. If you notice any improvement, then the ventilation duct work (often going through your floor or side wall) will need to be thoroughly cleaned. Also make sure you do not have multiple turns or kinks in the duct work. The more curves or turns this duct system has to take to exit the air outside, the more restricted it can get. The more restriction you experience the more time it will take the unit to dry.
Do you notice any unusual rumbling or rubbing noise when in use? This could indicate a faulty blower wheel. A blower wheel that is not firmly attached to the motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat (a fuse like component) may trip and turn off the heat circuit. A loose blower wheel will usually make a rumbling noise that is easily noticed. Inspecting the blower wheel is usually a task for a professional considering you must take apart most of your appliance to make sure it is tight to the motor shaft.
If you have a gas dryer, gas valves could also cause you an issue. Defective gas valves can create a symptom of taking too long to dry if they are intermittent and require professional attention. A professional is needed to check for proper flame ignition for a complete drying cycle to determine if this may be your point of concern.
On many dryers you will find "drum seals" in between the unit's drum and the front door. The drum seals are used to prevent excess air from entering the dryer drum and act as a cushion between the drum and the front and rear access. The drum seals are made up of a felt like material. If the seal is torn, or is worn, then clothing can become stuck in the gap when the drum is turning. This can produce a scraping or thumping noise and the clothes can also be ripped and/or have black marks on them. This will also affect your drying time tremendously.
While you are checking the drum seals please check the door of your dryer as well. When the door is closed in gas and electric dryers the door seal helps to keep cooler air from entering the drum. Keeping the correct temperature at all times inside the dryer ensures that the clothes will dry efficiently. If clothes are not drying then inspect the door seal for signs that it may be worn or damaged.
If none of the above solutions prove to be successful, it would be advisable to contact an experiencing repair tech to assist further.
Best of luck!
Nov 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
Taking 2 to 3 hours to dry a load of clothes...checked dryer vent from dryer to outside and it is not clogged.. what can the problem be?
Are the clothes hot when you take them out? If not, then maybe your heating element is broken. Easy to replace that, just pick one up from a parts store.
Our dryer started to take a long time to dry clothes but the heating element was working. We opened it up to check for lint and so on, and it turned out that the drum had slipped slightly out of location and the back of the dryer was partially obstructing the duct. That was probably what was making the dryer squeak, too. We reseated the drum easily in a few seconds and now it dries well again.
Feb 18, 2011 | Dryers
It takes the dryer 2 hours to dry the clothes. I always make sure lint filter is cleaned after each cycle.
Hello there and thanks for choosing fixya
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Feb 03, 2011 | Dryers
The Dryer heats up for a while and the stops heating after running for a while.
Without the specific model number to work with, I'm taking a guess that your dryer has a sensor at the back of the drum. That is the dryness sensor that the clothes rub against and let's the dryer determine if the clothes are dry, according to the setting you selected on the control knob.
First thing to do is use some Windex on a clean cloth to clean the senor strips as use of dryer softener sheets can leave a residue that builds up on the sensor and could be causing it to stop.
The other thing you can do is use the timed dry cycle to see if the dryer works correctly. If the dryer works OK in the regular timed cycle, then it is possible you have a defective sensor.
Without more information about your dryer, It is difficult to provide more possible diagnostic steps and provide you with a possible solution.
Jul 28, 2009 | Whirlpool Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Mayteg model DE313 clothes dryer that stopped drying clothes.
That is a very accurate assessment of the problem. Check the element for continuity between its two contacts. If there is none, replace it. If there is, look for a fuse on the side with two wires going to it. Test it for continuity. If there is none, replace it.
Jul 21, 2009 | Dryers
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Estate TGDS840JQ Gas Dryer Logo
101 people viewed this question
Top Estate Dryers Experts
John Tripp
John Tripp
Mike
Smitty
Level 1 Expert
Are you an Estate Dryer Expert? Answer questions, earn points and help others
