Question about Philips 46PP9302 46" Rear Projection Television
MINE IS AN 43P8341A 48 VERT. INCH REAR PROJECTION PHILIPS 2002
Got it second hand no remote and it's just slightly off, doubling the lines with slight color around, sounds like maybe the same pls. let me know if you can help. It's not much just enough for it to appear always slightly blurry.
    Scholar:
  • 93 Answers
Try getting the replacement remote
from here
Posted on Aug 20, 2008
    Master:
  • 623 Answers
Sounds like circuit board problem consult a technician
How do I adjust the convergence
In some cases you will need the original remote to adjust convergence. Check that first. You can also find more detailed guides on www.TvRepairKits.com - there is a tips page with service mode codes, etc, also.
Jan 29, 2013 | Philips 60PP9202 60" Rear Projection...
My 48 inch Magnavox HD is showing double Model #: 51mp392h/17
If it looks anything like the picture (3D etc) it will need the "Convergence circuit" repaired.
Let me know if you have questions.
Feb 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
There is A greenish double slightly lower than the picture. How do I adjust the lrnses without A remote?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 14, 2010 | Philips 51PP9303H Rear Projection...
My samsung sp50l2hx1x/rad rear projection lcd first had a couple of yellow patches that have slowly taken over the entire screen.
I also had the same problem i found that the rear pros have two layers for the screen the lenticular which is front one with vert lines and theres the fresnel which is thicker and clear when the two layers slightly seperate it causes a yellow tinge i removed mine and put it back together and it works fine now just a suggestion good luck.
Aug 27, 2009 | Televison & Video
The colors on our tv are slightly misaligned. I'd
hello i would order a remote first if the colours do not relign then it could be the convergance chips may be the problem good luck
shaun
Aug 06, 2009 | Philips 60PP9352 60" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
JVC 48 in rear
Probably the projection guns (my JVC had them fail on me). It started that way and eventually I had a triple image of what was on TV, one in red, one blue, one yellow, and all slightly offset from each other. The fix was new projection guns (thankfully it was under warranty as they were about $300 each).
Aug 08, 2008 | JVC AV-48WP30 48" Rear Projection...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture in narrow line on 35" Tube set
The problem you are describing is called loss of verticle deflection. You will find this will require diagnosis and there is no simple answer to this repair. Most likely there will be either bad electrolytic caps or bad vert. output IC in the vert. circuit.
Mar 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
