Question about Dishwashers
Westinghouse dishwasher virtuoso SB 925 not heating the water and not drying the dishes , still workig thou. Would it be expensive to repair?
  • Trevor C Sep 06, 2008
    Hi
    i have the same problem with a SB915 model - electronic board looks OK. Have you had any success?
    trev
  • theresa521 Jan 26, 2009
    I have the same heating problem with a westinghouse 907
I also had this problem of the water not heating up but the washer still did its thing. what i found was the problem, is the soldered joints on the circut board were cracked (dry joints) around the relay area, i just resoldered them and hay presto its all good
Posted on Sep 05, 2009
  • john mcqueen Jul 15, 2011
    I had the same problem and fixed it with this online help. Cheers !
Obuggerit was spot on. Found the same dry joint on the control board relay output. Saved at least $200, but you need basic electronics skills to fix it. Thanks, Dan
Posted on Oct 27, 2009
Hi, my westinghouse wsf6605xr dishwasher is not drying dishes. Any ideas?
The heating element may be burned out, pull it out and test it for continuity of the coil.
Feb 23, 2017 | Westinghouse Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
Hi My westinghouse virtuoso does not heat the water any more and i wan to know were is the heating element located please
if you want to see all the parts you can go to searsdirectparts.com and put in your model # and you can view every part and location of your machine.let me know if this helps.
Mar 06, 2010 | Dishwashers
Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
Aug 29, 2009 | Frigidaire Dishwashers
I just purchased an LDF6920. It does not dry the dishes. In fact, there is water remaining in the bottom, and all the dishes and drum and door are beaded with water. It suggests putting some sort of...
First off, there should not be any (visible) water standing in the bottom of the dishwasher after the cycle is done. If yes, check the drain, installation of drain line, etc.
Second: The LG is a very energy efficient dishwasher, but in order to acheive this, it does not use a heater to dry the dishes. It relies on the residual heat from the hot water used in the wash cycle, plus a small fan to vent some moist air. It is imparative that you have soft water and use a product such as Jet Dry to assist with drying on the LG dishwashers. Even at that, plastic items (which retain little heat from the water) will not dry well, if at all. Plates, pots, glass, anything with some mass will dry. You may have to adjust the Jet Dry dispenser setting up a bit. If it is set too high, you will get white streaks on your dishes, so then back it off just a bit.
Aug 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Does a LG model LDF 6920st have anything way to heat to hot water
Dishwashers do have a water heater element. In fact, it's the same heater that is used for hot dry, but you can switch it off for the drying cycle if you want. Dishwashers heat the water so it will be hot enough to properly clean the dishes. Sorry, you lose the bet.
Nov 26, 2008 | LG Dishwashers
Dishwashers Logo
1,851 people viewed this question
Top Dishwashers Experts
