Question about Maytag Refrigerators
I have a Maytag wide by side model number mzd2665he that I bought brand new on 10/20/2006. I came home from work today to a floor full of water from my defrosted food and ice. The fridge is running like it is working, but is not cooling at all. I have no idea of what the problem is, but I certainly hope that it is not a serious problem, as this fridge is only a year and a half old. Please help!
  • msmalls Aug 20, 2008
    Thanks for the suggestion! I will definitely take a look at the drip tray as a solution. I really hope this is the problem.
  • 706 Answers
You probably need to empty your evaporator drip tray.. Try this website and punch in your fridge model number.. they have drawings and parts lists for you to review... http://www.pcappliancerepair.com/model-display.php
Hope this helps...
Posted on Aug 20, 2008
Icemaker doesn't work. Creaking noise. I suspect water is not getting to the icemaker. Any ideas?
Unplug frige.Remove ice maker use a hair dryer to defrost water inlet gutter. Reinstall ice maker.
Aug 13, 2015 | Maytag MZD2665HE Side by Side Refrigerator
Frost builds up on the chute betwen the icemaker and the door dispenser unit.
I need you to confirm your model number. Is MZD2665HE correct? The problem is very likely a broken 12565502 Dispenser Door Spring or more providing you have the correct model number. There may be a kit if the model number is different.Thanks, John Tripp Appliance 911
Jan 31, 2014 | Maytag MZD2665HE Side by Side Refrigerator
I HAVE 25.6 WIDE BY SIDE CAME HOME ONE DAY AND THERE WAS WATER ON THE FLOOR IT STILL COOLS VERY LITTLE BUT WILL NOT FREEZE
I had a similar problem on my kitchenaid refrigerator a few months ago. All it took was replacing the compressor start device relay and it started working again.
Jul 24, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag freezer does not work. it hums and stops
if you evap fan is not working this wouldnt produce any coldness,, or possibly it sounds like your compressor start realy is tryin to start but not working,,,
Feb 03, 2010 | Maytag MZD2665HE Side by Side Refrigerator
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
394 people viewed this question
Top Maytag Refrigerators Experts
isaac johny
isaac johny
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
