My large screen, rear projection, VS-55705 has vertical vibrating and or rolling lines when first turned on. This usually goes away after awhile. Now it is also doing it after the TV has been on and working properly and does not correct itself.
  • wildh2ocb Nov 26, 2008
    vertical rolling will not stop. vertical control in front will not stop this !
  • 927 Answers
Good Day, monkeysbiz;
Try this : CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Replcace the caps first then IC if don't get the proper voltage. The parts are at the very back of the Signal board on the right hand side. Good Luck, big IRISH.
Posted on Aug 20, 2008
SOURCE:
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
May 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
White lines
i have same problem, i have 55 projection tv mitsubishi, i get those white lines. how can i fix the problem.?
thank you.
Mar 27, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Picture flitters and lines rolling form top to bottom or vise versa, when you first turn it on the picture is also bent then the bent goes away
ya cheak that and all circuits on bord for fine line cracks solder those back toghter clean it also get dust out of it well
Jan 19, 2008 | Mitsubishi VS-55705 55" Rear Projection...
55IN TV.
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01
Oct 31, 2007 | Mitsubishi VS-50605 50" Rear Projection...
PICTURE DISTORTED
you have defective small capacitor at vertical section! replace a new one!
Oct 03, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Projection guns not working
I've seen a lot of vertical problems on those older mitsu's. If it has been intermitant some of those would get bad solder connections on the deflection yoke ( the transformer slid up on the neck of the picture tubes) ther are three and it could be any one. the thing about it is you have to slide it down and take it apart to get to the area that would get the bad connections. If you do not know what you are doing the setup afterwards could be a mess. This is the first thing that comes to mind but be warned there are many many possibilities for what you are describing. good luck
Apr 25, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
Nov 02, 2006 | Mitsubishi VS-55705 55" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Ekse
