Question about MA Audio HK4000D Car Audio Amplifier
One more i figured out what i did qwrong i hooked my remote into my speaker and my speaker into the remote section and its not working properly now its givein me some loud noises and speaker just goes off when it feels its needed ......how much would it cost to repair it ?
  • ewarren2007 Aug 20, 2008
    so if it doesnt make any noise with the rcas connected then my head unit is blown but if its hooked up and makes noise then the amp is gone
  • 631 Answers
Does it make any strange noise with no RCA cables plugged into it?
If not, you need to check the shield grounds on your head unit.
Click HERE for the test procedure.
Posted on Aug 20, 2008
  • Perry Babin Aug 20, 2008
    Damage to the head unit can cause the amplifier to do strange things. We need to know if the head unit is working properly before you can do more troubleshooting.
Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
May 04, 2011 | Toshiba VC-L2B Remote Control
Hooked up the amp, lights up, fans kick on and run fine, speakers hooked up proper, no sound? hooked up speakers to another amp and they work fine. Fuses are all good too. Thoughts?
could be bad rca cables or no output from the radio rca outputs. the sub control may be turned off on the radio (ive seen that alot at my work). if all that is fine, the amplifier may be bad. the rca cables may be plugged into the "out" section of the amp. gotta look at all the small obvious things first. good luck.
Dec 18, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Only my left and right speakers work - they are all connected
you probably hit a button saying 2 CH or 2 Channel which cuts out the other speakers. find a button that says dolby Digital or the surround button
Aug 06, 2009 | Pioneer VSX-D608 Receiver
Sub jacks play but door speakers wont play when hooked up to proper wires why
your car has a stock amp for the speakers hook up the blue wire that is on the stock lead wire harness to the remote wire along with the remote for the amp
Jun 29, 2009 | Audiovox VM9311TS
Need home theater hooked to TV with built in DVD
This is the easiest way 2 explain it. Hook up on the home theater should be labeled in and out. same as on the tv. The TV might no have that feature as the DVD is built in. You might just have an option for sound from the TV/DVD to the home theater. Again OUT from TV IN to receiver. Same with any other device set up.
Jan 27, 2009 | Durabrand 5.1 Surround Sound Computer...
No sourround sound
read your manual well and double check all your connections,make sure the remote is working, check the battery contacts in it too. If you haven't got a manual, obtain one.
Sep 29, 2008 | Denon AVR-1706 Receiver
No sounds from rear speakers..... Yamaha HTR-5650
Select different modes on the remote or front panel and make sure all speaker that you have hooked up are showing on display. Are the Lt & Rt channels at least playing audio? If you want, i can step you thur some steps to try in live chat if you want today. Let me know as i have experience in this area! Sincerely Guru Jay
Jan 03, 2008 | Yamaha HTR-5650 Receiver
NO SOUND
hi there, no sound means an amplifier section problem, start with the speakers, test the speaker then check the amplifier section, it maybe some jack problem or remote mutting error. ty
Jan 01, 2008 | Disney DT1900-P 19" TV
No sound at all
The jumpers are there to connect the preamp section to the power amp section and are required for the receiver to opperate properly. Make sure the receiver is set to the proper input, in this case: CD. If there are A/B speaker connections, be sure the receiver is set to match the connectors you're using. If there is still no sound, profesional service will be required.
Sep 26, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Noise on rear speakers
yeah i used to have this problem too forever, untill i was playing around with them and figured out the problem. on your remote there is a shift function, while holding shift you need to turn up rear speakers also on the remote, i think its near 1 or 2 or somthing. just look for rear level, turn that up and make sure you have the proper audio setting and that should fix it.
Oct 17, 2006 | JVC MX-J800 CD Shelf System
Open Questions:
MA Audio HK4000D Car Audio Amplifier Logo
42 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
