Contributor
- Posted on Jun 14, 2011
Re: I change belts on decks now they are smokeing hot...
Check the pulley that has the engagement cable attached to it, there should also be a spring that pulls the pulley back when you disengage it. If that spring is not there, the belt will still have a little tension on it causing it to rub on the drive pulley creating heat.
