Question about NetGear WGR614 Wireless Router
PLease Help When trying to install my netgear roater, it ask for the IP Address and other such information...Where do I get this information?
  • 4 Answers
The router should get the IP address on it's own when connected to a DSL or cable modem. If it's needing an IP address then it should be from the modem. The router can have an issue if the modem and router use the same IP range. Try changing router to 192.168.2.1. This can stop the possible conflict for why it's not getting info on it's own.
Posted on Aug 20, 2008
Where is the WEP/WPA code on a Netgear router
The WEP / WPA security information can be obtained by accessing your Netgear router setup page. You'll need the router's IP address to access the setup page. From your computer, go to Start > Run > type "cmd" (w/o the quotes), hit Enter > DOS black screen appears, type "ipconfig" (w/o the quotes), hit Enter. Take note of the Default Gateway IP address - that is your router's IP address.
Pull up a browser and enter the IP address in the address bar, hit Enter. You will then be asked for your router's Username and Password, enter the required information. If you don't know the info, please contact your router manufacturer for assistance. Once you're in the router setup page, go to the wireless security settings to check the WEP or WPA code.
Should you still need further assistance on this matter, please contact your router manufacturer.
I hope this helps.
Feb 04, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
I have a MacIntosh computer and wanted to install NetGear WGPS606 54 Mbps Wireless Print Server w/4 Port Switch to serve a Canon Pixma MP830. The hangup is the IP address assigned to the printer. I had...
You can assign ip with 2 method 1 is manually and other is automatic .
If you set manualy ip you must need to set gateway as your printers and other computer's gateway.
Subnetmask is same in all system.
For example if your netgear lan ip is 192.168.1.1 then your printer ip 192.168.1.5 sunet mask as 255.255.255.0 and gateway is 192.168.1.1
Other computer's ip 192.168.1.6 subnet mask 255.255.255.0 gateway 192.168.1.1
Make sure the printer driver installed and it is in network.
IF you want ip from netgear then you need to enable dhcp in it.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1 or
http://192.168.0.1 or
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on dhcp then enable save settings and restart netgear.
Then in printer set ip get automatic from router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 14, 2010 | Computers & Internet
I can't connect to the internet
Is the issu on the wireless connection or wired connection through the router. Could you provide the below information:
# Connect your computer directly to your modem and perform the following tests.
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here. Also, mail us the same IP configuration.
Above information will help me provide u an accurate resolution
Jul 06, 2009 | NetGear WGT624 Wireless Router
Netgear SmartWizard Help
Is there an option to use a dynamically assigned IP address (also called DHCP)?
That's most likely the option you need, almost all home Internet providers use DHCP to assign the information you are asking for automatically to your Internet connected device (in this case, your router).
Let me know what options are available to you if neither Automatic or DHCP is.
Thanks!
Mar 29, 2009 | NetGear WGR614 Wireless Router
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear usb adapter will not acquire ip address from router
Most laptops have a wireless card built in them and if you have one you should try using that instead and form past experiences USB adapters don't generally work on laptops in which case if you laptop has the slot for it you should buy a card like this http://www.netgear.com/Products/Adapters/SuperGWirelessAdapters/WG511T.aspx
Wrong IP address entered when installing NetGear WGR614v7
If you are refering to the router, there is a small button you can use a pen to press and hold while the router is on, Hold for about 10 to 15 secs - You will see the lights change as its resetting. That will reset the router back to factory defaults. You can then follow the directions from your manual or goto Netgears website and look up the manual there which will be in PDF format.
Please give more details on what you are trying to do by setting an ip address. You maybe making things more complicated than need be.
G'luck
Nov 11, 2008 | NetGear WGR614 Wireless Router
No connection trough router
Hi Thumbsucker,
Oftentimes with Netgear routers, before an Internet connection can be established, you'll need to run the Wizard setup routine on the router itself. Many other manufacturers don't require this, but if you're connecting to a PPPoE connection (such as DSL) then the Netgear requires said basic setup.
On the bottom of the router itself you'll see some information. It'll tell you the default IP address (such as 192.168.0.1) and a basic username and password (the default for most Netgear routers is admin for the username and password for the password). Plug your computer into one of the four switch ports on the router (not the uplink/Internet port) and type in the IP address of the router (again, such as 192.168.0.1) into your Web Browser (such as Internet Explorer). If it asks for a username/password then punch in the info given on the bottom of the router. At that point you should be able to answer the basic questions to get you online.
There is a chance that your modem and your router have the same IP address; in that case, you'll need to manually change the IP address on the router.
If by chance you can't get into the router via the information provided on the bottom of the device, take a paper clip and, with the router powered up, hold in the reset button for 30 full seconds. This will reset the device to its default factory settings.
Ben
Mar 01, 2008 | NetGear WGR614 Wireless Router
How to install netgear fvs318 vpn firewall?
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Dec 15, 2007 | NetGear FVS318 Cable/DSL ProSafe VPN...
NetGear WGR614 Wireless Router Logo
63 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
