Question about Microsoft Office Professional 2007 Full Version for PC
Problems changing default language from US english to Aust english
Could you please advise on how i can stop my dictionary changing from AUST english to US english. It seems that nothing i try to do stops it from changing back. Thank you.
  • 2 more comments
  • orthoww Aug 20, 2008
    Thank you for your help. I have done what you have suggested but it does not seem to help as the language just reverts back to US english again......!!!!!!
  • lruda Nov 12, 2008
    All of a sudden when taping a program and then playing it back it is in Spanish. I have gone into both menus on my TV and VCR and reverted back to English, but this does not help or work.
  • Anonymous Dec 28, 2008
    problem changing language to english
  • gallmann Apr 05, 2009
    My Sansa 4gb player has defauted to Spanish. How do I change it to Engllish?
    Scholar:
  • 107 Answers
Try this:
Rename these keys: Start > Run > type regedit > press <Enter> > Navigate to the following key and right-click and rename it to:
HKEY_CURRENT_USER\Software\Microsoft\Shared Tools\Proofing Tools\1.0old
Reboot, Open Office app/Word?, and Office will recreate it, hopefully resolving that issue.
Posted on Jan 03, 2009
  • 236 Answers
Hi orthoww,
To change the default dictionary in Office 2007:
Click on start - All Programs, then on Microsoft Office, then on Microsoft Office Tools, then on Microsoft Office 2007 Language Settings.
A window will pop up, and in that window, make sure that "Primary Editing Language" (bottom option) is set to AUST english.
Then click OK.
Then open up your program, and your default dictionary should be set to the language you wanted.
Posted on Aug 20, 2008
  • Dave MacPhee
    Dave MacPhee Aug 20, 2008
    You may need to change the default language in Windows Itself. Try the following: (taken from Microsoft article found HERE)
    Set the default input language in Windows Vista
    1. Click Start, and then click Control Panel.
    2. Under Clock, Language, and Region, click Change keyboards or other input methods.
      Note In Classic view, double-click Regional and Language Options, and then click the Keyboards and Languages tab.
    3. On the Keyboards and Languages tab, click Change keyboards. This displays the Text Services and Input Languages dialog box.
    4. Under Default input language, click the language you want to use as the default language, and then go to Step 10.
      If the language you want to use as the default input language is not listed, do Steps 5 through 9.
      Note The default language you click is applied to all programs on your computer that use this setting, including programs from other companies.
    5. Under Installed services, click Add.
    6. Expand the language that you want to use as the default input language, and then expand Keyboard.
    7. Select the check box for the keyboard or Input Method Editor (IME) (IME: A program that enters East Asian text (Traditional Chinese, Simplified Chinese, Japanese, or Korean) into programs by converting keystrokes into complex East Asian characters. The IME is treated as an alternate type of keyboard layout.) you want to use, and then click OK. The language is added to the Default input language list.
    8. Under Default input language, click the language you want to use as the default language.
    9. To close the Text Services and Input Languages dialog box, click OK.
    10. Turn on the language-specific options for the default language in Microsoft Office by doing the following:
      1. Click Start, point to All Programs, point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office 2007 Language Settings. This displays the Microsoft Office Language Settings 2007 dialog box.
      2. Click the Editing Languages tab.
      3. In the Primary editing language list, click the primary language in which you plan to work.
        Notes
        • If the language you want is not in the Primary editing language list, click the language from the Available editing languages list and add it to the Enabled editing languages list, and then click it in the Primary editing language list.
        • For more information about the Microsoft Office Language Settings 2007 dialog box options, see Microsoft Office Language Settings.
    Top of Page
    Set the default input language in Windows XP
    2. Click Date, Time, Language, and Regional Options, and then click Regional and Language Options.
      Note In Classic view, double-click Regional and Language Options.
    3. Click the Languages tab, and then under Text services and input languages, click Details. This displays the Text Services and Input Languages dialog box.
    4. Under Default input language click the language that you want to use as the default language, and then go to Step 9.
      If the language you want to use as the default input language is not listed, do Steps 5 through 8.
    6. Click the language that you want from the Input Language list.
    7. Under Default input language click the language you want to use as the default language.
    8. To close the Text Services and Input Languages dialog box, click OK.
    9. Turn on the language-specific options for the default language in Microsoft Office by doing the following:
        Notes
        • If the language that you want is not in the Primary editing language list, click the language from the Available editing languages list and add it to the Enabled editing languages list, and then click it in the Primary editing language list.
        • For more information about the Microsoft Office Language Settings 2007 dialog box, see Microsoft Office Language Settings.
    Top of Page
  • Dave MacPhee
    also, in my first post, go into the same area
    (Click on start - All Programs, then on Microsoft Office, then on Microsoft Office Tools, then on Microsoft Office 2007 Language Settings.)
    And add your language you want in the "Enable Editing Languages" box, and then click on the English US language and click remove. Now click OK, and see if that works
I have a Spanish computer with XP on. My problem is that this is obviously in Spanish and I want to change to English. Do I have to buy new software?
To change the default language on your computer, goto the control panel - Regional and Language Options. You will need to make changes on all three tabs- Regional Options, Languages & Advanced. Changing the defaults to English on each of these tabs will change most programs to the default language of the system settings. You will need to reboot your computer for these changes to take affect. Please be aware that the default language is changed for all users of the computer.
Some specialized programs that were installed may have to be reinstalled if all the languages were not installed by default, but overall you should not have any problems.
Happy Computing, Myridom
Mar 05, 2011 | Microsoft Computers & Internet
How can i change my loptops language? it is in a danish language but i cant understand danish . i want it to be in english .. can you help me? please .
1. go to control panel and choose date,language and time setting
2.choose regional option
3.set all the language in engish US, language in english and advance in english
4. after restart your computer to take effect of the settings
Nov 13, 2010 | Microsoft Office Professional 2007 Full...
How to change microsoft word language
If you want to have english spelling pick from the upper toolbar:
Tools - Language - Set Language.
If you want to change the interface, you will have to reinstall the whole MS Office.
Had the same problem :-)
Mike
http://www.mswordhelp.com
Apr 28, 2010 | Microsoft Office Word 2007 Upgrade:...
My office language is in German.I want to change it to english
1. Please go to the bottom of any word document.
2. Click on the language tab (will show current language, eg. "German").
3. Select the desired language (eg. "English (U.S.)").
4. Then select the "Default" button (to make it the default language for every future document).
You can also check this link to get detailed information.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 27, 2010 | Microsoft Office Professional 2007 Full...
Where is winword dictionary file and what is its extension?
Note: The steps below are for Word 2003 or Word 2002. The procedure for Windows 2007 is different. There is a Microsoft KB article that provides instructions. In Word 2007, this file is called “exclusion dictionary”.
Before you build your exclude dictionary, you need the name of your main dictionary file. You also need to make sure Windows Explorer can see hidden files and folders.
The file name of your main dictionary and location varies. It's based on your Microsoft Word version and your language. For most users, the file name will be some version of mssp*.lex and can be found at:
[drive]:\Program Files\Common Files\Microsoft Shared\PROOF
It’s common when you search for mssp*.lex to see multiple files:
MSSP3EN.LEX
MSSP3ENA.LEX
These files are the main dictionaries for English as indicated by the EN. However, the second file is for Australia. If you’re using French, you might have MSSP3FR.LEX
Jun 18, 2009 | Microsoft Word 2007 for PC
Spell checker has defaulted from English to foreign language
Go to the Review Tab in Microsoft Word. Click on Set Language (fifth option from the left). Select English (United States).
May 08, 2009 | Microsoft Office Professional 2007 Full...
I can't write ? : ; ? etc... correctly :S
Go to your control panel and select Regional & Language settings.
Make sure the Formats tab has English as the current format, the select the "Keyboard and Languages" tab, select Change keyboards, and make sure the default input language is English.
Apr 14, 2009 | Microsoft Office Professional 2007 Full...
Ms office pro 2007 all programs are in french
Where di you purchase you Office professional if it is not Office professional English you have to purchase English language pack for more information call Microsoft
Apr 10, 2009 | Microsoft Office Professional 2007 Full...
Outlook Express wrong language
You have to install a dictionary. Go search for a dictionary and install it. Sometimes the dictionary with Office 2007 will not work with Outlook Express. I use to do support for Office.
Dec 16, 2007 | Microsoft Office Standard for PC
MS access
Have you tried changing your Regional settings in Control Panel? This should change your language in all MS Applications.
Best of luck
DeltaC
Oct 11, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
1,121 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
