Projector won't stay on
I have a Sharp XG H400U LCD Projector. In a nutshell it won't stay on. I power it up and it shuts down. While on (however brief) the lamp light is green. I've cleaned the filter. Won't the lamp light be red if I need a lamp? I don't have a manual. Any ideas what's wrong with this unit?
  • 1 more comment
  • wabishop57 Jan 05, 2009
    I have the same problem, when i turn it on it will stay on for about 15 minutes then it turns off, fan and all. I can immediately turn it back on but it will only stay on for a few seconds before turning back off. If i leave it off for a while, then turn it back on, it will stay on for another 15 minutes before turning back off.
  • visions1 Jan 06, 2009
    I have the same prob, but turns off immediately.Can see the lamp strike just before it turns off.
  • fixyaglh Jan 18, 2009
    Problem with Optoma EP739 projector: Projects seems to start normally; after about 1 - 2 minutes of use after apparent self-check, lamp turns off and indicator light on top of projector (labeled "Lamp") switches from green to red. Manual says "When the “LAMP” indicator lights solid red, the projector will automatically shut itself down. Please contact your local reseller or service center." The nearest reseller for me is around 4000 km away. I've left telephone messages at a US sales and service center, but do not get return calls. If there are no ready, simple fixes (or things to try), I suppose I can mail-order a new, inexpensive projector, and anticipate potentially replacing it every 2 - 3 years. Even at $1000 each, replacing at such an interval would be cheaper for me than buying a similar Optoma and having a problem every 3 years.
Most projectors have a filter that can be removed and cleaned. Perhaps it is clogged or you may need a new bulb.
Posted on Apr 27, 2009
I was givin a sharp LCD projector XG-H400U and I am having a problem getting it to turn on. When I plug it in the lamp flashes then nothing! Is the lamp bad or is something else wrong?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Aug 14, 2011 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Is there an operations manual for a Sharp xg-h400u lcd projector available? Trying to locate info on how to setup convergence.
Not interested in paying for the answer on an 18 year old projector. I'll work through the problem and ask other people I know if they have a solution!!!!!!!
Feb 04, 2010 | Sharp Televison & Video
My Sharp XG-E650UB does not power on or show power indication.
Have a nice day!
Jerry
Lampdeng Limited
Aug 23, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Sharp XG-E650UB LCD Projector won't display picture.
it only takes up to a 640x480 resolution. it is a very antiquated projector.
Aug 10, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Aug 07, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
No Power or indication of power to Sharp XG-E650UB Projector
Have a nice day!
Jerry
Lampdeng Limited
Jan 28, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
Sharp xg-h400u projector Lamp timer reset.
plug the projector in. Do not turn it on.
hold the menu, enter, and down keys at the same time....
Press On
The map will turn on and the screen should display Lamp 0000H
Pg 54 of the xr-10x manual -- http://www.sharpusa.com/files/pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
May 22, 2008 | Office Equipment & Supplies
Sharp Notevision 6 XG-NV6xU
reset the lamp hours on your projector
Jul 28, 2007 | Sharp Notevision XG-NV6XU Multimedia...
1,322 people viewed this question
jasbo
jasbo
