Question about Bernina Bernette 75
Bernina Bernette 65 sewing machine is not sewing properly. Thread is bunching up from the bobbin. I have re-thread the bobbin and the machine and read the manual. Ideas?
  • 4 more comments
  • drlinn Nov 02, 2008
    Help for the above problem.
  • sophiecreid Dec 28, 2008
    i have the same problem, and a quick google search suggests that this is a failing of the actual machine. I only just got it back from the shop - made one simple top, and now its happened again.
  • Anonymous Feb 27, 2009
    any one have the manual? could you please updoad? I lost mine
  • Anonymous Mar 10, 2009
    the bobbin holder popped out. How do I fix it?
  • drlinn May 11, 2010
    Mine is doing the same thing. I have tried everything from re-threading, changing the needle, taking it apart, etc. What is the solution?
  • Anonymous Mar 15, 2014
    bernette 65 bobbin cover missing, where can I buy the part?
  • 19 Answers
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
Posted on Nov 11, 2009
I have a problem with filling bobbin evenly
Posted on Feb 12, 2011
Bobbin is toren up will not go back in the case
Posted on Aug 31, 2010
HELP!
I am trying to sew with shirring elastic, I have shirring elastic in the bobbin and thread on the top and I am using a denim needle. I have tried adjusting bobin tension and I am using the longest stitch at the top. It is not happening. Can anyone tell me what I am doing wrong?
Posted on Jan 14, 2010
  • Tally Girl
    Tally Girl Apr 27, 2011
    You want the shirring elastic to be stretched by the tension device as the seam is formed so it will need to be under tension in the bobbin holder. You may find that adjusting your bobbin tension just isn't enough to achieve this - if so, when winding the bobbin with the elastic, keep tension on it so it is wound with some stretching of the elastic. Or hand wind it to achieve this. Failing that, you can always abandon putting the elastic through the bobbin, just lie it on the fabric and use regular thread top and bottom in a zig zag over the elastic (don't catch the elastic with the needle, just go over it. Then repeat for your rows of shirring and gather it all at the end by pulling the ends of the shirring and knotting them off. This actually gives a nice finish and means the fabric stays flat until you want to gather it which is easier to get straight rows.
When I press the pedal the string get tangled and I also have problems with the bobbin thread not being picked up! Please help! Thanks margaret
thread the machine correctly( follow the operators manual)
wind the bobbin properly and when placing the bobbin in the bobbin carrier pull the thread down the small slot and under the spring plate
thread for the needle always comes in from the left (The side of the groove in the needle ) and out the cut away side
pull a long piece of thread for the needle out and hold it while you turn the machine over
after 1 or 2 revolutions the needle thread will bring up the bobbin thread and you then pull both threads out a bit
if you don't have a user/operators manual there are 2 options
one is to go google and type in --user manual for bernina bernette model 65 sewing machine and down load the pdf version
the other option is to visit manchester shops ( cloth and fabric shops ) and talk with the sales people as may of these places have a sewing circle of people who will be only to willing to help you.
Feb 25, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Why won't my Bernette 65 pick up the bobbin thread
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 14, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
My bernette 65 is bunching underneath. How do I resolve that?
Grasp the threads and hold them down when you start your seam. If it still happens make sure your thread is seated into your upper tension mechanisms. If that still isn't solving your problem... CLEAN between the tension discs with some sturdy fabric folded in half. (wax build up from threads can cause issues)
Good luck
Aug 04, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
My Bernette 65 sewing machine isn't pulling my main thread through. Bobbin tread is being pulled fine. What could the problem be?
Make sure you have a new needle in first and the correct way round, failing that the machine may need retiming
Sep 19, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
BERNINA 802 BOBBIN THREAD WILL NOT COME UP THROUGH THE NEEDLE HOLE
try this
first make sure the needle is not damaged
make sure there is a 3-5 inch tail for the bobbin thread
make sure there is a 3-5 inch tail for the top thread & hold the top thread tail with your fingers (away from the needle) now with your other hand use the handwheel on the right side of the machine to slowly lower the needle down to the bobbin area & see if it will pick up the bobbin thread
Sep 25, 2010 | Bernina BERNETTE 65 Mechanical Sewing...
Machine is threaded but the needle will not pick up the bobbin thread. How do I fix on my bernina 65 machine?
Make sure the needle is not bent and is threaded from the front to the back.
The needle should be installed with the flat side of the needle shaft facing the back of the sewing machine.
Lower & raise the threaded needle, holding onto the end of the thread.
Then begin to sew.
If this does not help, then it may be the timing needs to be adjusted and this has to be done by a Bernina repair tech.
Apr 20, 2010 | Bernina Bernette 75
Burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Jul 16, 2009 | Bernina Bernette 75
Sewing Machines Logo
2,022 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
