Question about Kenmore Elite HE4 Electric Dryer
Kenmore He5 Dryer
I have a Kenmore He5 Dryer and when I put clothes in it and shut the door, the door keeps popping open BEFORE the cycle is done drying. Why is this happening and what can I do to fix it?
  • Anonymous Mar 17, 2014
    My Kenmore dryer starts fine but cuts off mid cycle like the clothes are done. What would cause this
  • senorahicks Oct 06, 2017
    I'm having the same issue - cuts off mid cycle before clothes are done. I believe it thinks the door is open.
    Genius:
  • 1,028 Answers
Try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Posted on Aug 20, 2008
I have a Kenmore he5 steam dryer that is dripping water out of the steam nozzle on the inside of the drum. This happens on any drying cycle and causes clothes to not dry. How do I fix this?
Does it drip just when the unit is operating or do you find water in the machine when it is not running? Try shutting the water off to the dryer and see if the dripping stops. If it does the water inlet valve needs to be replaced.
Feb 12, 2016 | Kenmore Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
I have a Kenmore elite he5 gas dryer and when it is turned on it will not spin. Can you tell me why?
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings OTHER WISE CHECK FOR A LOOSE WORN BELT
Feb 15, 2015 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
746 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
