Question about Coleman (100076) Compact Refrigerator
Craftsman generator, several years old, used less than 100 hrs. Oil level full, generator on level cement floor, new gasoline, plug cleaned, set at .30 and is firing,chkd. spark arrester OK, filter never got dirty but blew it out anyway,ignition on, gas on pulled rope dozens of time, choke, full, half, and none,pulled rope dozens of time, choke, full, half, and none, run, but the *#@!xv#@! won't start. For past several years machine has started on first, no later than second pull. Please help, We live in Florida, and there's a hurricane in Florida.
  • mcle5802 Aug 30, 2008
    I hav a Craftsman Generator that I used for Hurricane Katrina. I used it for 20 days straight and didn't have a problem. When I was finished I put it up and never used it again. Now it won't start. I did everything but it still won't start. I was told that it has a low oil shutoff switch. I was told to change the oil and it should start. Well it doesn't start. Can i bypass that switch? Help there is a hurricarne coming and I need to get this done.
  • 33 Answers
Pour a little raw fuel into carb intake. try to start. if engine runs for a few seconds and quits the problem is more than likely a clogged carb. go to auto store and get a gallon can of carb clreaner and dissassemble carb and lower into bucket and let soak over nite. you'll want to get a carb kit to replace any gaskets that may get messed up during tear down. when you go back together make sure to wash any residue of cleaner out of carb and use a small nozzel air blower on air hose to blow out ALL passages any needle valves have to screw into. take a can of carb cleaner and with the small straw place over hole and squirt into hole. make sure cleaner come out some where in carb body. that way you know all the passages are open. reassemble and crank her up.also invest in a compression guage. remove pllug and screw gauge into plug hole. pull sharply at least 5 times and see what the reading on the guage is. should be at least 70 or better. if rings and valves in good condition don't be surprised at a reading of 120 or better.
Posted on Apr 21, 2009
Sounds like the carburator has got dirt in it, or it needs to be replaced. Take it to a service shop that can replace the carburator or do it yourself.
Posted on Sep 17, 2008
  • 958 Answers
Could be a leaky valve,
test it by unscrewing the plug, then cover with your finger the hole and pull, see if there is big pressure coming out of the hole.
if there is a little pressure, try pouring engine oil about half a pint, in the hole where you remove the plugs, then slowly pull the rope as if you're gonna start it. the oil would come out of the hole. you want to oil the intake and dischrge valves to seal it to the head.
i did that to an old generator of mine who have not been used for 3 months.
who knows, it might work...
tnx 4 using fixya..
drcool
Posted on Aug 21, 2008
My generator has a slight oil leak but starts right up but stops after 2 mins. It will restart but will not stay on. Live in Florida and need for pending hurricane
"Slight oil leak" where? if the oil level gets too low, or if the leak is depriving some mechanism of its lubrication, the motor will do exactly that. Possibly try turning the main shaft after it has stopped running, and see if it no longer turns freely. Does it get really hot? If so, don't run it until you find what is making it so hot. In one of my engines, the oil got water in it, turned thick and looked like a weird frappe, and the oil was no longer good. Check for leaks and fix them.
It could also be from the ignition failing, if it is 4-cycle. Maybe the glow plug, if it is 2-cycle.
Sep 07, 2017 | Electrical Supplies
Honda generator wont start it was running fine.
If you filled the fuel tank with gasoline enhanced with ethanol the fuel may be bad and caused the carburetor to gum up. Also Honda engines have a low oil sensor and from your description of the oil, can cause problems with the sensor and the engine won't start. Try changing the oil first and then adding a small engine gasoline additive that helps with stale gasoline starting problems.
Sep 10, 2016 | Honda Electrical Supplies
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
My generator won't start. I started it when I first got it about a year ago. It's been in my garage for about a year.
Remove and clean/check/replace the spark plug first, spray some WD-40 in the cylinder, Remove all old fuel and just fill with enough fuel to run it. If you are comfortable removing the carb then it should be dipped/cleaned. Check to ensure the kill switch is not engaged/unplugged. Lemmee know then we can go further!
Jul 18, 2011 | Coleman Powermate Powermate 5000W...
I have a Kohler generator set model KT17 that was not run for several years and was full of old gasoline. It would not start at all so I replaced plugs, cleaned fuel pump & filter, then cleaned carb...
Check the genset controller for a fault, low oil psi, no output voltage, overspeed, overcrank / no crank disconnect signal / starter staying engaged, high engine temp.
Jun 26, 2011 | Kohler Electrical Supplies
I have a 5.5 Vertical Briggs and Stratton about 6 years old that is mounted on a woodsplitter. This year it started dieing under load. It's driving a brand new 2 stage 11 gallon pump because I thought that...
If the generator was used during these 6 years continuously on full or near full load, it may have loosed compression (and derated load).
If you can measure the pump current and compare with the rated of the generator it should be less than the half of the rated to run properly in continuous mode. If it is greater than 75% it may be more than the possible for this generator.
Nevertheless the new fine oil, the overheating or lowering of the oil level during operation may be the reason for stopping.
Jul 06, 2010 | Briggs Stratton H7159 & Stratton® 5500,...
Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Feb 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Coleman (100076) Compact Refrigerator Logo
1,082 people viewed this question
Top Coleman Home Experts
john h
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
