Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Will print from pc but will not scan
I need to scan some pictures into my pc but when I press the scan button it gives a check connection error. I had to reinstall the printer a few months back. Please help. Thanks Kelly
  • 48 Answers
Maybe you need new drivers..
www.brother.com has them by model number and operating system.
you may wish to remove old software first, though with add/remove program
Also, more printer resources are here
Posted on Aug 21, 2008
Why does my canon PIXMA 452 say pc not connected when I hit the start scan button
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
Jun 09, 2014 | Canon Pixma MX452
When I press Scan on my Brother MFC440CN, I get an error message ''Check Connection''. I just want to scan a picture to card, which I did many times without an issue.
instead of scanning using the button on the machine try it from the computer. Brother normally gives the control center program, you can find it in all programs in the brother folder. you should be able to scan from here. if not there is probably a connection problem from the printer to the computer
Mar 24, 2010 | Office Equipment & Supplies
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
I am trying to scan photos onto the computer
How is it connected? Via usb?  Have you tried powering the printer and pc off and back on?  Try to print something, go into your print que and make sure that there are no errors.  If using usb, try another port if you have one.  Also check your ink levels.  HP AIO wont work with low ink levels.
Mar 27, 2009 | HP PSC 1210v All-In-One InkJet Printer
HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Mar 12, 2009 | HP Laserjet M2727nf Multifunction Printer
HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
Can't scan documents
For the system to work completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of awkward, download Picasa 3 and if you have installed the scan driver correctly, you can use Picasa to import the scans by controlling the printer. It also allws for some other tweaks that are not so easy to get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
Jul 31, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Scanning problems
reload your driver that came with the printer,be sure to go to properties and select shared.Although the print and scan functions use the same network cable they have diferent IP addresses and the driver software assighs the IP for scan funtion.
Mar 03, 2008 | Kyocera CS-2550 Black and White Copier
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
138 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
