I came home and the house was hot! i have 2 ac units the upstairs unit is running downstairs is not. i discovered the breaker had been tripped, i reset it and still the ac unit does not turn on
  • mrchrisfox Aug 20, 2008
    There is no receptacle, this unit is outside and is on a direct feed from the breaker box (I presume) the only thing in the house is the thermostat. there is a a sqare d box next to the AC unit with a plastic type pull handle on it. i pulled it out ..no fuses..just what appears to be contacts. i put it back in..no change..and yes i am concerned as to what tripped the breaker to begin with...not sure about that yet. where else could a fuse be?
  • 706 Answers
After you switched the breaker back on, did you test the outlet for power without the AC plugged into it? You may have a bad receptacle or faulty wiring to that receptacle...The breaker tripped for a reason..any over current condition could cause that..including a bad recepetacle.. too many loads drawing current in excess of the rating for that breaker. Is the AC unit the ONLY thing on that breakers feed? If you want to check the integrity of that AC unit.. and its not too big,.. either get a heavy duty extension cable and provide AC from a known good feed or bring tha AC unit up to the same location as the other one and plug it in there.. if it works there.. chances are you have a service problem.. Hope that helps..
Posted on Aug 20, 2008
    Genius:
  • 2,920 Answers
You should have a set of fuses somewhere near the ac unit separate from your breaker box replace the fuses
SOURCE:
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
Fri. I get home from work and wife says no hot water. I tripped the breaker and still no hot water. I then replace the breaker and still no hot water. I'm thinking I have a power problem between the...
Check to see if there is a GFI outlet in the house or garage. Reset if tripped. My wife would trip the GFI in the garage when she used the hair dryer in upstairs bathroom.
Apr 24, 2011 | TitanNet TITANTANKLESS. COM PRESENTS THE...
AC unit seems to be working normally but not cooling house
If you are referring to the secondary pan there could be a problem with your drain line.i would find the drain at the exterior of your home and **** it out with a wet vac..most A.H.Us have float switches or moisture sensors.They will shut down the unit if the drain clogs.
Jun 21, 2009 | Weather King 10AJA3601AH Air Conditioner
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
224 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
