During an electrical storm my unit experience a power surge that caused my step down transformer to burn. Replaced step down transformer and check my voltage without thermostat connected. The compressor unit does not come on and my condenser unit only hums. What else could I be over looking outside of purchasing a new one.
  • 706 Answers
Chances are that if your Air Conditioner was the recipient of a high voltage transient that took out your transformer, that same transient could very well have smoked any number of other components in the control system. It may not be worth investing any more $$$ and time to troubleshoot and replace components at this point. If by chance you had a reasonable selection of replacement components that you could cycle in it and test, you might have a shot... otherwise.. I would write it off... ( your call..and probably not what you wanted to hear but merely my humble opinion)..
Posted on Aug 20, 2008
No sound on my Vizio E420VL
It could be a burned audio output IC, or the source switch IC, you need a hot-air soldering gun to replace it.
Aug 20, 2017 | Vizio Televison & Video
Coleman electric Furnace won't come on seems not to receive input from thermostat
There probably is a little transformer that runs the thermostat, at the furnace. If it is separate, it is easy to replace.
Nov 25, 2013 | Heating & Cooling
Rudd furnace>>>> power surge.
Some circuit boards have a built in transformer and others have the transformer that sits right beside the board depending on the age of the furnace. First, look for a small 3 or 5 amp fuse on the circuit board. Check it, and if its good, and you have a small ohm/volt meter. Check your transformer. You can either ohm it out or just check for voltage. You have a "high" voltage side and a "low voltage" side of the transformer. The "high" voltage side will go to the power (120 volt) that comes into the furnace. This would probably be the side that would burn out during an elec. storm. To ohm the transformer: (This will be your best way to check)
1) shut off power to the furnace
2) pull the two wires loose that go to the "high voltage side"
3) put the leads from your ohm meter to each wire that goes to the transformer, and you should get some kind of reading. If not the "high voltage" side of the transformer is burnt out
You can follow those three steps to the "low voltage side as well, just remember where you take any wires off.
Be sure you have the power turned OFF. Good luck, hope this helps you.
Apr 18, 2011 | Heating & Cooling
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
Wii wont turn on, nothing had a lightning storm last night and now nothing
Try replacing the power cable, many times when there is a power surge and you do not have a surge protector it will burn out the transformer on the power cord. If you replace it and still nothing, most likely your Wii has been burned out by a power surge.
Feb 28, 2011 | Nintendo Wii Console
Hello! I have a Malibu transformer for my outdoor lighting. Last night, we had a severe rain storm. During the storm, my outdoor lighting went out. When I went to check the transformer box this...
My malibu transformer has a reset button on the back near the terminal connections. If the transformer is on (time displays on the panel) but the light fixtures are not lit, look for the reset button on the back and depress it.
Oct 07, 2010 | Malibu Hardware & Accessories
I have a 5ton package unit electric/natural gas. unit is 2yrs old. There is 220 v0lts to the unit. unit will not come on. there was some voltage surge during bad weather at the time unit went down. the...
This can only be 1--of 2 things, (the easy fix first, transformer or curcuit board is bad) .If you have 220 volts then check for power going into the transformer, (220 vt) and then power going out, (24-28vt) (90% of the time, its the transformer, 10% of the time, its the cuircuit board.! , i
Sep 13, 2008 | Goodman Heating & Cooling
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
Problem with upper cabinent of Maytag Drying Center.
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
Dec 02, 2007 | Maytag Neptune MCE8000AY Electric Dryer
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
