Question about GE 27GT271 TV
Need to hook up dvd player
All this 1999 tv has is cable hookup screw on thing...and 2 holes that say focus and screen...help, im a girl...what do i do???
  • 4,234 Answers
In order to connect a DVD player to this set, you need to purchase an RF converter. This will take the 3 cables (Red/White/Yellow) and convert them to either channel 3 or 4 that can be seen thru the TV. Connection instructions will come with the converter.
Dan
Posted on Aug 20, 2008
Fixed with an rf adaptor...thanx
Want to see dvd hookup for model#ln32b360c5dxza want to .Picturepicture of back of tv
See this link for the manual - looks like the hookup diagram is on page 6:
http://www.manualslib.com/products/Samsung-Ln32b360c5dxza-2824887.html
Feb 08, 2015 | Televison & Video
My dvd player was unhooked from my tv during a move. i no longer have the dvd manual. apparently I am connecting something incorrectly, because I have audio but no video. can you help with a verbal or...
The DVD player and Tv set connections are made in ur tv,by what kind set up?Like by a RCA components cables Y,R,W RCA cable?Just follow the DVD player output holes hook up RCA cable Y,R,W to the DVD player out holes hookup to tv set input holes like Y,R,W input holes.Check the RCA connections cables pull out and re connected in those holes a couples times sometimes old equipment must do that for ensure contact are made.Might have a damage set of RCA cable set.Might have replace another RCA cable set.Or ur setup using a S-video cable set and used a RCA cable R,W cable only for audio only?Than S-video cable probally got shorted must be replaced.
Aug 04, 2011 | Panasonic Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Can not install to telivision, need help with wire connections,do not know what hookups go where lost manual,have three connections on wire,red,yellow and white, where do they go on dvd player and to where...
This is very simple
First on the back of your dvd player there should be the holes with the same colors as the cable you have, yellow (video in) in the yellow, red (left audio) in the red e.t.c.
Then either on the side or the back of your tv there should be the same sorta thing, depends if you have a HD TV or a regular freeview/analog tv. With hd there should be green blue red white and yellow, just the same as the DVD player, plug the cables into the right colors as i said,
Same goes for the regular TV, just do exactly the same as you have done with the dvd player,
Switch your channel to dvi or av1/2/3 and your dvd player should be working
Regards
Jul 25, 2009 | GPX D1816 DVD Player
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Ps3 hookup to panasonic plasma viera
Actually if you do have a ps2 you don`t really need a Dvd upconverter because Ps3 is a full Dvd player +blu Ray Hi Definition.I suggest to take the dvd out and just use the ps3 as a Dvd player
Good Luck
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
Dvd/vcr player is hooked up but not playing...
Yes. You definitely need to set your TV on a specific channel - GAME, in your case. Check your TV manual how to get to that GAME channel.
Jan 12, 2008 | Philips DVP3340V
GE 27GT271 TV Logo
196 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
