Question about Microwave Ovens
Our GE Spacemaker stopped heating half way through a batch of pop-corn. the light,turntable.clock and everything else works. I tapped a tube that looks like it is covered in aluminum foil and it worked one more day, but that's it. Model JVM1442--900 watts
  • 706 Answers
You probably have a worn out Magnetron Tube... That's the part that generates the Microwave Energy that causes food to cook.. GE has a history of bad Magnetrons so I am not surprised yours failed.. It could also be the transformer for it too.. in either case.. they aren't cheap so you may be better off just buying a replacement microwave... your call.. a magnetron could cost you ~ $250 or so ..Transformer is simlar in price.. depending on the model.. Hope that helps... Also: word of caution.. when dealing with Microwave energy components.. you could get seriously injured if you do the wrong thing and the RF shielding is compromised.. We typically do an RF check after a replacement to make sure the system is safe.. Hope that helps..
Posted on Aug 20, 2008
Why does my ge spacemaker jvm1740dd1cc no longer heats and the turntable does not work?
Bad door switch. Look for burnt terminals on one of the door switches. Replace the switch and cut off the burnt terminals and splice on new ones.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Clock,lights and turntable work but does not heat
Open the microvave discharge the capcitors.If you don't know then stop here and call pro .
Open it First check physically the nothing is burnt.I everything seems okay then, check the resistance of the magnetron and also the fuse.PLEASE DON'T TRY IF YOU DON'T KNOW HOW TO DISCHAGRE THE CAPACITORS.
Thanks
Please rate my work
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works (clock,lights,turntable) but it does not heat. Is it better to fix or replace?
If everything works and it does not heat, the problem lies with the magnetron circuit. Typically the magnetron fails and the replacement part is almost as much as a new oven. For this model the price of the magnetron is about $80. Unless you really love this oven, your better off replacing it.
Jan 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
159 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
