Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Ok...next... Thanks...thanks.... Ok, both fan filters are clean. Power supply is good (I just replaced the entire Power P.W.B. board with one from a working unit). Lamp sensor is good (making good contact on its switch). So...the indication of the TEMP LED blinking could mean could mean what? Or should I worry about what it means? Again...many thanks...
  • 927 Answers
Good Day, egear00;
Try looking at this, since you sound like a TECH;
The Fan alarm is activated when the Fan does not run. This can happen in two different circumstances.
  1. When the Fan Fails due to a malfunction.
  2. When the Power is turned off. The FAN +12 regulators turn off and the fans quit.
(1) When the Fan Fails:
In this situation the fan alarm will be activated. Inside each fan is a hall element that keeps pin 1 of the connector pulled low when the fan rotates. If the fan stops, the pull up resistor connected back to the Fan 12+ pulls the alarm line high. This high is routed through two Diodes to the shutdown circuit of Q905, Q906. When the base of Q905 goes high, it's collector pulls the Power 1 (Power On) command line low which shuts off the relay driver Q903. The purpose of Q906 is to make the shutdown circuit appear like an SCR. If there's any pull up voltage being supplied, (in this case from the Power 1 line), the emitter to collector current of Q906 will keep Q905 in the On condition. This circuit will remain latched as long as the Power 1 line remain in the on condition.
An additional route for the Fan Alarm is out the PPS2 connector pin 9 to Q562. The Fan Alarm high will cause Q562 to turn on and pull the Fan Alarm pin 48 of the Microprocessor low. When pin 48 goes low, the Microprocessor will in turn activate the Temp LED and cause it to Blink. (See the Temp Alarm Circuit for more details).
(2) When the Power is turned off.
When the Power is turned off, the Fans do not run because the Fan +12V regulators I906 and I907 are turned off. This would generate a false Fan Alarm, so the Microprocessor outputs a High from pin 56 to Pin 7 of the PPS2 connector. This high turn on the Fan Alarm Enable transistor Q908. When Q908 is turned on, the collector is held low to prevent a Fan Alarm. This low keeps D916 and D918 cathodes held low.
Ok...next... - click-to-view.gif Click to view Larger Image separately.
Good Luck, big IRISH.
Posted on Aug 20, 2008
Fan has started to run constantly and very noisily can i fix this myself
  1. Clean the CPU fan.
  2. Clean the power supply fan.
  3. If the noise persists and can be narrowed down to the CPU fan, replace the CPU fan.
  4. If the noise persists and can be narrowed down to the fan inside of the power supply, replace the power supply.
    Note: Due to safety concerns, it is never recommended to open the power supply and replace only the fan. I always recommend that the entire power supply be replaced instead.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | HP G70-460US Notebook
The tv cannot start. No red standby lights even though the switch was turned on. I changed the fuse and it doesn't work still. I have tried turning the switch behind the tv too.
Hi Julia,
Your unit missing some output voltage(s) in the power supply section. This is commonly caused by open/shorted voltage regulator IC, open fusible resistor, leaky/dried electrolytic filter capacitor in the power supply section. You can't fix this kind of problem if you don't have necessary tools and test instrument, don't know safety precaution. But good news, you may replaced the entire board for your convenient. Click the link below to have an idea how much money you are going to spend on the board.
http://shop.ebay.com/i.html?_nkw=LG+32LG30&_sacat=0&_odkw=Harman+Kardon+AVR+2500&_osacat=0&_trksid=p3286.c0.m270.l1313
http://www.shopjimmy.com/catalogsearch/result/?q=LG+32LG30.
If you still wish to save some money, I would advice you to send your power supply board to repair shop. There's some shop that repair only the power supply board even not sending the entire unit. It will charged you a much cheaper.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 01, 2011 | LG 32LG30 32 in. LCD HDTV
Viewsonic VX2835wm won't turn on. Did the usual troubleshooting but to no avail. I have two others that work just fine. Any suggestions? Thanks!
There are 2 boards/parts involved with this problem
a) The power supply board:
The main problem are 4 bad/defective capacitors
1. 22uf 400v
2. 47uf 50v
3. 1uf 100v
4. 22uf 35v
You can find them near the PWM IC controller (U601). Replaced all these capacitors regardless they look good. I pulled them out off the board and tested them with my Blue ESR and capacitor tester and found 3 were defective.
Next, you need at least 97% Isoprophyl alcohol and toothbrush to clean the soldering paste. Due to overheating on the primary section / HOT section the soldering leads tend to produce brownish paste which is causing the component parts to SHORT. Concentrate at the back of the board, especially at the U102 (16-pin IC) and Q202 transistor by scrubbing them carefully. I used magnifier to make sure the legs are clean and shiny. Clean the rest of the back and some part on top of the board. Let it dry for 2 hours at least. I did 2 times this cleaning to complete the process.
b) The Main Board
The main board has 2 bad capacitors at C124 and C126. I replaced them and cleaned also the board with alcohol.
That's it. Good Luck.
Roan Mac
Computer Tech
Chapel Hill, NC
Aug 13, 2010 | ViewSonic VX2835wm Monitor
LONG PEEP ,I TRIED ANEW RAM AND NEW VGA BUT NOTHING CHANGE
I am guessing, that you have your board laying flat, and the computer is unhooked from all the cables.
first thing is to make sure that all your sockets are clear of dust by blowing high pressure air to the board (dust is a killer of boards).
ok onto the next step turn the computer over to check for lose screws that might have dropped onto the motherboard
ok next is that all of your cards are clean dust free you can take a static free cloth or high pressure air to clean/clear your cards then replace all the cards and memory sticks
if you have a extra power supply that you know is good or a friend has one thats good try hooking that up first.
If your computer fire's up now then you can try your power supply if dosen't work then you have boiled your problem down to your power supply and that it should be replaced
Dec 26, 2009 | DFI NT70-SC Motherboard
Dell MFP 1600n Power Supply Failure - need part identification
I found a replacement board on the internet for $89.00, then realized you could replace the entire unit for about $200. So I threw it away.
Oct 01, 2009 | Dell 1600n All-In-One Laser Printer
No display will not operate no fan no light
Ok, there is an in-line fuse that is located inside the unit on the power supply board. if this fuse is damaged, replace it. If this fuse is ok, replace the entire power supply board.
Jun 01, 2009 | Whirlpool GH4155XP Microwave Oven
Intel 210882 mother board power won't spool up fans or anything.
usually power supplies comes in different voltage n wattage . check ur mother board manual that which type of powre supply it support than replace it with the good one.it may solve ur problem.thanks
Apr 17, 2009 | Intel Motherboard
Power drops aprox 1 minute after start
Good day!
It's the power supply, usually the fan of power supply run once it start normally, Replace the power supply. And try to turn on the unit.
Feel also some part of the mother board if they are hot like the heat sink the power supply casing do it when the power is off.
Thanks.
Nov 06, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Getting close...thanks
egear00; OK, you have voltage, check this:
1. Filters make sure both are clean
2. Check the power supply and check for bad CAP's
3. Check the lamp sensor.
Aug 19, 2008 | Hitachi 60V500 60" Rear Projection...
Not touch with metal part
Are you sure that your power supply is good, try to short the GREEN and GRAY pin if the power supply fan is running the fan is ok but if the fan not running you need to replace the power supply. I the Power supply is good try to remove the cmos jumper and open the computer then return again the jumper. If you can't hear a sound beeping try to remove the processor and insert again maybe the processor pin or lock is loosen .
May 05, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
