Question about GE Kitchen Ranges
Model # JKS06bof4bb wall oven has a fault f-7 dc Tried cycling power on/off didnt work still have fault
I have a whirlpool accubake oven model WFE364LVS. The screen is saying d79b. What does that mean? The oven door doesn't open either. My husband did the self clean and it worked fine for alittle while after and then I went to bake a cake and the door wouldn't open. Can anyone please help me?
Posted on Nov 07, 2014
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Maytag gas range model MGR5750ADW
hi thanks for the question the part you need is the oven sensor witch is located , in the oven top left /looks like a pen replace that part the number i got is 1365 from repair clinic . thanks the appliance doc
Posted on Sep 28, 2008
  • 1015 Answers
SOURCE: My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Posted on Jan 18, 2010
I have an Electrolux icon floor model. I set it to clean after pulling the racks, the lock light came on but nothing happened. I left it for about 15 mins and still nothing. I turned off the clean cycle...
On the E30EW85ESP3 model I had to pull the racks "and" the supports mounted on the side walls. Otherwise it would not allow the clean cycle to begin. Hope this helps.
Dec 20, 2012 | Electrolux ICON Designer E30SO75ESS Oven
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
GE model #JTP18SDSS electric wall oven displays F-7 and will not work. Tried disconnecting for a few minutes --- still doesn't work.
this is a function pad is jammed or stuck.Recommend that you try to un stick the pad or replace the electronic control
Dec 31, 2010 | GE JKP15 Electric Single Oven
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
After cleaning oven the fan will not go off and a F2 or F3 flashes.Turned power off and fan starts up as soon as power is restored. I think I pressed wrong timer when I set the oven to clean. I had to get...
It will help to know what f2 & f3 stand for. These are fault codes and there usually is a tech sheet taped to the back of the oven, or inside the control compartment of the oven. If you open thecontrol area, you can look at the sheet and know what failed by the list of fault codes. Unfortunetly, it could be the control board again (these are very fickle electronics), or it could be the oven lock mechanism,or the overheat sensor that keeps telling the fan and other components to stay in their operating mode. it is like the domino effect: one item goes flukey and the rest fall prey to the results. Good luck, Macgivor
Dec 27, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
Microwave Oven shuts off after 5 seconds
What type of microwave is it (make and model)?
May 25, 2009 | Panasonic NN-S592 Microwave Oven
F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven. I haved turned off power at breaker and restarted. Fault reoccurs. Oven is definitely cool. It has been 36 hrs...
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Nov 07, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Kitchen Ranges Logo
168 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
