Question about Canon BJC S450 InkJet Printer
Cannon s450 Hello, I wanted to tell you we have the same problem as mllent-one green and six orange blinking light. We tried your procedure and had no luck! First, I'm not sure it is for the same printer, because we have two buttons, one the power and the other one I thought was the reset button! When we tried your procedure, there was no beep. actually, it didn't do anything that was mentioned! Do you think we need a new printer? My wife was printing something one time and it musn't of finished. the next day when I booted up a popup came up and asked if I wanted to finish printing. I didn't know she had tried to print anything so I clicked on no. Since then we haven't been able to print. I hadn't looked at the printer before the popup showed, so I don't know if it was blinking before I clicked on no! Can you please help? Dennis
    Scholar:
  • 49 Answers
G'Day Dennis,
OK try turning off printer at power point and leave for 10 to 15 minutes before starting again then try this reset proceedure again.
If it doesn't work, a new printer might be cheaper than taking yours for service, but if you use compatible inks, the price differance for cartridges might make a repair worthwhile.
Canon S450 Printer
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release Power button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press Power to set data
Posted on Aug 20, 2008
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
I have just added new ink and the light is now blinking green then orange, what is wrong please
Must be your printer's ink should be reset.
Here is how:
1. Power off printer
4: Continue to hold POWER & Press RESUME twice then release both power & resume
5: When the indicator lights steady, press RESUME three times. The indicator should be orange.
6: Press Power to set data
Nov 20, 2010 | Canon BJC S450 InkJet Printer
Cannon i80 - message Waste Ink Tank Full
Follow this procedure:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
6) Power off then back on and test.
Don't forged to replace the waste ink absorption pad.
Oct 05, 2009 | Canon i80 InkJet Printer
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Cannon Canon i960 Photo Printer
Can not print from my Cannon i950. 'paper thikness lever position
A friend of mine had the same problem and turned out to be the print head. They can be pricey so a new printer would be in order probably. Could also be the waste ink counter as well. Here are some steps to see if you can get rid of the 7 orange blinks:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
If this doesn't work then you know its the print head for sure.
Feb 10, 2009 | Canon i950 InkJet Photo Printer
Canon S450
From what I can tell the 6 orange lights indicate a print head failure. Why the print head has failed is another question maybe too old (I've read somewhere that they only operate for a fixed amount of time), maybe printed enough pages (somewhere else indicated that they only print a fixed number of pages). The solution is to replace the printhead (not just the ink tanks).
There is no way to know which print head needs replacing, so unless you have a spare one you will just have to choose which to change, and if you get it wrong try the other one. It appears to be an expensive way of solving the problem (but I have just found it cheaper to buy a print head which comes with 3 tanks than to buy 3 separate tanks!).
Paul
Nov 19, 2008 | Canon BJC S450 InkJet Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Canon S450 not responding
Try resetting the printer like this
Canon S450 Printer
Jul 05, 2008 | Canon BJC S450 InkJet Printer
Service Error with my cannon printer 160
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon S450 printer not responding
NO BJ Cartridge Orange 6   Re-install cartridge or replace ityou probably don't have the ink cartridge installed correctly. make sure it is pushed and seated properly.
Oct 14, 2007 | Canon BJC S450 InkJet Printer
Canon BJC S450 InkJet Printer Logo
81 people viewed this question
old marine
old marine
