Question about Relisys RLT1720 17" LCD Monitor
Laptop monitor computer screen displays upside down
  • 82 Answers
One simple step.
Hold CTRL and ALT key and then press up aroow or down arrow.
You are there.
Posted on Oct 10, 2008
    Champion:
  • 293 Answers
Hi...there,
Try your toolbars bottom R/H side, look for your VGA settings. Right click on VGA settings and look for rotation settings. After that you should know what to do...
Posted on Oct 04, 2008
4 Suggested Answers
SOURCE: computer screen is upside down
press alt + ctrl + the up arrow
Posted on Nov 19, 2007
bhiga
  • 119 Answers
SOURCE: Display is completely upside down
Try connecting it to a different computer. If it's upside-down on another computer, then the panel is probably mounted upside-down. If it can be removed from the stand, remove it and see if it can be mounted the other way.
If it's correct on another computer, then your graphics settings are incorrect. Assuming you're running Windows, go to Display Properties, Settings tab, click Advanced button, look for a tab describing your video adapter (usually ATI or NVIDIA). In the video adapter's setup there is usually a Rotation option. The rotation option may be set to 180-degrees instead of Normal or 0-degrees.
Posted on Apr 05, 2008
proton77
  • 1183 Answers
SOURCE: My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
Posted on Mar 22, 2009
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Nov 27, 2014 | Samsung SyncMaster 913N 19" LCD Monitor
P c screen upsidedown
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures.
Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees.
Rotating the computer screen allows for more display options.
For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop.
Press "CTRL" + "ALT" at the same time.
Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees.
The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation.
Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation.
Windows 7 Monitor Orientation
Click the Start menu at the lower-left hand part of the screen, and open the Control Panel.
Select "Display," then click "Change display settings" from the left column.
When using multiple monitors, select the monitor that you would like to rotate.
Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference.
Click "Apply" in the Display Settings window.
Click "OK" to finish.
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
My webcam has all of sudden started displaying upside down views.
you mean you webcam picture turned upside down or whole monitor screen turned upside down?
Mar 31, 2011 | ASUS Computers & Internet
My Sony webbie screen is upside down.how do I fix it
Upside down display
Caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Some computers do not have this function
Jun 14, 2010 | Xerox XR619DW Monitor
Thanks
proton
Mar 22, 2009 | Dell E193FP 19" LCD Monitor
Video output is upside down on Monitor.
Hi Koofah,
To fix the issue press Ctrl-Alt-Up. To permanently fix the problem go to:
Start >> Control Panel >> Display >> Settings >> Advanced
Where it is after that it dependent upon your video card.
Fixya!
Season's Greetings!
Chris (ziraffa)
Dec 23, 2008 | Toshiba Satellite A65-S126 Notebook
Hyundai flat screen monitor upside down display help?
There are 4 screws on the back that connect the monitor to the stand. Remove them and turn the monitor right side up and replace the screws tightly. OR you can change your layout in your video card settings.
Nov 20, 2008 | Hyundai L91A 19" LCD Monitor
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Display on moitor
just press the auto button on panel it will adjust the screen
Aug 17, 2007 | Compaq FP 7317 17" LCD Monitor
Relisys RLT1720 17" LCD Monitor Logo
71 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
