It makes a clicking sound when i press the power button but dosent turn on
  • Tone
    Tone Jun 04, 2012
    Hi my hitachi 51 tv is doing the same thing yours was doing.What was your solution.thanks
  • 927 Answers
Good Day, nhl1fan;
The TV is getting power and the main fuse is okay. Try unplugging the TV from the outlet for 3 to 5 minutes then plug back in A/C outlet.
If no fix your TV has something inside that is shorted (drawing too much current), then call an authorized Service Center to give an estimate before proceeding with the repair.
Good Luck, big IRISH.
Posted on Aug 20, 2008
When i press the power button on the remote to turn my 52inch tv on it doesn't start and makes a clicking sound as if its trying to come on
What is the brand name to your TV? Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 25, 2012 | Televison & Video
IPHONE DOSENT TURN ON
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 28, 2012 | Apple iPhone 3G
The air conditioner went out on my car when i turn it on it dosent do anything i can just hear a click noise like its trying to turn on and when i press the off button it makes some kind of hissing noise...
You might have caught the leak down in time...try adding some R134 refrigerant...if your system is low on the refrigerant...this initially causes the symptom you are describing...I know it sounds silly to add refrigerant during the winter...but you are trying to save the compressor...:) Hope this helps.
Jan 17, 2011 | 2002 Mercury Grand Marquis
It wont start i press the power button and it jus make a click sound, but it doesn't turn on
I have the same problem. Worked for 10 minutes and then turned off and every button just makes a clicking noise - no lights or other sign of life. Solution anyone?
Dec 17, 2010 | Panasonic SCBT330 Theater System
Will not turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not syncronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work.
May 14, 2010 | Nintendo Wii Console
My wii won't turn on
May 13, 2010 | Nintendo Wii Console
Not swicthing on when preesing the on button and jumpy picturce
trty to turn it on by the controller. hold the power button or push start twice and hold it the second time. if it dosent turn on you mite have a situation with the power suply. try moving it to another outlet to see if it is the outlet if not then it mite be the power brick.
Dec 11, 2009 | Microsoft Xbox 360 Console
Computer won't turn on
Try a different power outlet, or plug directly into the wall.
This does sound like a bad power supply. You can get replacement power supplies just about everywhere computers are sold. It'll set you back about $50 and is relatively easy to install.
-=/ Daft Tech /=-
Oct 23, 2009 | Computers & Internet
Can the emerson universal remote control the RCA surround sound?
more than likely yes depending on if it has an aux button if so most of the time u turn the device on hold the aux button down till it blinks or stays solid lite up then press the power button and press up till the device turns off if that dosent work refer to the manual and it will give u a code just use the dvd settings
Dec 27, 2008 | Televison & Video
Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Jun 14, 2008 | GE 25GT507 25" TV
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
