You should contact yourMEIKO Authorized Service AgentIF:
•The utensil washer encounters a problem but does not display
an error code, OR •An error code appears that is not shown here, OR
•The listed action fails to correct the problem.
An Authorized Service Agency Listing was supplied with your
utensil washer. If you do not have the listing, call 1-800-868-3840
for assistance.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
It's known as the "Blue Screen of Death" Because they usually require Formatting and starting over.
BUT, Not always. Write down the code that is usually along the top in white font. Google it and see if there is a cure. When I did I get several solutions like these. Be Careful you don't buy anything you don't want. Some sites are free. Note the first option below is from Micrisoft.
Go to www.Futura-support.com. You can download a manual there and then you'll have a better chance Since I don't know which Futura model you have, it's hard for me to tell you what the E1 message. means. Find your model on the website and download the appropriate manual. That should give you the answer you need.
info 420 means shortage of rinse agent reported "ready for washing"state. you may have an empty or low rinse in your bottle , also could be filter on your dosing tube slightly bloked , or your doing pipe may be bloked . if not them your pump might be fauty
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle.
This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch.
Hope this info is of use to you ,
Kitcheneer
