Logitech Subwoofer X540 PC Speaker system
Does anyone have any information on where I could get a new transformer for the sub? Information on part is: CEFW6636-02-1 , input:120 Vac 60Hz , output: 14.6 Vdc 2.4 amps. It has 07020 stamped on the top of the transformer.
Please email me at [email protected] if you have any information regarding this.
Thank you very much.
  • rookw Aug 30, 2008
    Same problem...120VAC in, OK, no DCV out of transformer. System seldom used...batch of faulty transformers? [email protected]
3 Suggested Answers
SOURCE:
heavyice
  • 374 Answers
SOURCE: The mains transformer in my logitech x540 has
You would need to rewind the coils.Do not try to do it by yourself if you have no idea what you are up-to...this time it was transformer next time it could it could be your circuit.Take it to a professional,the charges won't be much.
Good Luck.
Posted on Dec 27, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Logitech Subwoofer X540 PC speaker System
HELLO THERE AND WELCOME TO FIXYA
IF YOU ARE NEEDING PARTS FOR YOUR SYSTEM YOU CAN GO TO THE FOLLOWING
Wild Burro Audio Labs - DIY Full Range Speakers THEY CAN GET WHAT YOU NEED AND EVEN HELP WITH SPECS AND REPAIRS AND ALSO IF YOU CONTACT THE MANUFACTURE OF THE SYSTEM THIS IS A GREAT HELP FOR YOU OK?
BEST REGARDS MIKE
Posted on Dec 29, 2011
Subwoofer sound weird I don't know what is the
maybe something in the speaker(s) are broken.
Mar 20, 2013 | Audio Players & Recorders
BEST REGARDS MIKE
Dec 28, 2011 | Logitech Audio Players & Recorders
How to install my logitech x540 to tv AOC 32"
all speakers are connected in Sub wofer finaly connected sub wofer to system speaker out put green pin
Feb 17, 2010 | Logitech X-540 Computer Speakers
The mains transformer in my Logitech x540 has blown (oc on the primary). I've taken it out and its a simple single coil primary and secondary, but there are no markings on it to indicate the secondary...
Good Luck.
Dec 27, 2009 | Logitech X-540 Multimedia Surround Sound...
Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at [email protected]?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Apr 02, 2009 | Logitech X-230 Computer Speakers
Subwoofer with speaker wire?
Back in the old days, subwoofers were powered by the voltage from your receiver, through speaker wire.
Nowadays, subwoofers have their own power, hence not having speaker wire connections anymore.
It's unlikely that you'll be able to connect your old subwoofer to your new receiver.
You'd need to get a new one, which if you don't mind buying closeout, can be found on eBay pretty cheap.
Mar 16, 2009 | Sony DAV-DX255 System
Logitech X540 PC speakers, rear speakers only working; LAPTOP
Goodday remmember that you have to have a 5.1 sound card to be able to use a 5.1 sorround sound system.the 5.1 has more plug inputs to plug all the speaker FRONT REAR and SUB.
Jan 03, 2009 | Logitech X-540 Computer Speakers
How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Oct 27, 2008 | Logitech Z-340 Computer Speakers
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
1,130 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
