Question about Lexmark X1270 All-In-One InkJet Printer
X1270 NO COLOR PRINTING
PRINTER WILL NOT PRINT COLOR AT ALL NEW CARTRIDGES
  • 1 more comment
  • 2ted Aug 21, 2008
    lemark x1270 all in one printer will not print in color, and gives no error message. Reinserting the power supply on back while holding down the power button causes printer to spew a chart, which I suspect is a status register display, but have no idea what it means. Have already removed and reinstalled drivers, both from original disk and from website. Have tried new cartridge. Have disassembled printer and found no obvious fuse. reassembled fails the same way...any other ideas...cheap printer but I hate to waste it.
  • Anonymous Sep 07, 2008
    The print job goes through and it "prints" but there's nothing on the page when colour is selected.
  • Anonymous Dec 12, 2008
    Same and doesn't have any errors
    what is the answer i dnt understand ..x.x
Nope tape has been removed from new cartridge and the old cartridge has been refilled several times and the tape lost long ago.
But thanks for trying
2ted
Posted on Aug 22, 2008
    Scholar:
  • 152 Answers
I know what you mean by an inexpensive printer. The cartridges cost more than the printers! A simple, but often overlooked solution is to make sure that the tape protecting the bottom of the cartridge has been removed. Check that and let me know the results.
4 Suggested Answers
SOURCE: lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Posted on Apr 01, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
evelasco
  • 52 Answers
SOURCE: Lexmark X1270 Not printing.
Did you put the right numbers of the cartridges?
Posted on Oct 02, 2008
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
Can a no.16 print cartridge be used on this printer?
Yes. #16 black cartridge is compatible with Lexmark X1270 printer. Other compatible cartridges are: #17 (black), #26 (color) and #27 (color). Hope this helps.
Jul 18, 2010 | Lexmark X1270 All-In-One InkJet Printer
Unable to print red.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 04, 2010 | Lexmark X1270 All-In-One InkJet Printer
Sep 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 not printing in color
Is the cartridge a Lexmark cartridge or a refilled cartridge?
Remove the cartridge from the printer, take a damp paper towell and wipe the cartridge in one direction on the bottom. Is Ink coming out? If yes then put the cartridge back in the printer and try to print again. If the answer is no and the cartridge is brand new you need to return it to you point of sale and get a new one as its a bad cartridge.
If the cartridge is a refilled cartridge that is probably the problem. Lexmark printers do not support refilled cartridges.
Thanks
Catherine
Sep 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270
Does the printer attempt to print? Did you replace the black or colored ink? If it was the black ink will it print in color?
If it prints in color, check the black ink cartridge for tape residue on the gold contacts. The blue tape will sometimes leave the adhesive on the cartridge and not the tape. It cleans off easy with a soft cloth.
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Will not print color
The printhead is dry. I cant say that getting it wet will help because thats dangerous with electronic equipment. But its what i did to mine and it works now.
Apr 11, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270 will not print color even though it's saying it's full
I've had the lexmark too. the ink dries out in the cartridges.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark black cartridge-and printer x1270 not printing black
Nov 08, 2007 | Lexmark Inkjet Z517 Photo Printer
Lexmark X1270 All-In-One InkJet Printer Logo
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
