Question about iLO MP3 Player
Button stuck I have an older version of the Ilo MP3 player, which I can send you a picture of if you need me to. The power button is stuck in and so I can't cut it on. Is there anything I can do to fix this problem?
  • 3 Answers
Not sure if this is the right model, but this fixed mine
*always make sure your grounded when working with electronics
you can carefully pop the casing at where the usb port connects to the case. carefully take out the pcb and look where the play button is, if you inspect the button, one of the prongs on the very end may be broken.. (mine looks like an S with the button in the middle).
i super glued mine on the ends where the button connects to the case and it works just great now.
-Arokhdraggon
Posted on Jun 22, 2009
  • 8,596 Answers
No - manufacturer no longer supports. Count yourself lucky- this is the worst mp3 player ever made
Posted on Sep 07, 2008
2GB ILO MP3
Hold in the volume + button, connect to your pc, and pray
Aug 01, 2008 | iLO MP3 Player
Stuck on loading screen
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 31, 2008 | iLO (2 GB) MP3 Player
Frozen Mp3 player
Most of the time, this problem only requires a simple reset. ILo went out of the Mp3 business, so the manual is no longer available to the general public. If your player came with a manual, I would double-check it to see what reset method they reccomend. Also, ILo was notorious for creating websites that were not intuitive - there was no ilo.com or ilo.org, for instance. If your user's manual lists a specific website, if you would kinfdly post it here - many people would benefit.
Most of the time, this freezing issue is caused because the new version of Windows Media Player, version 11, was not compatible with the iLO player. If the manual lists an address for a firmware upgrade I would use that address (and post it also). It is highly likely, however, that the firmware upgrade is not available any longer. A firmware upgrade would resolve the problem permanently.
If there is no firmware upgrade available, and the simple reset does not work, then:
-Tha Mp3 Doctor
May 30, 2008 | iLO (2 GB) MP3 Player
Wont' turn on
HI
Ilo Mp3 Player is weak in Power button so many people get same problem open the case and reinsert the power button still not working, change the rupper piece under the power switch
Bye Take Care
Apr 15, 2008 | iLO (2 GB) MP3 Player
Power button repair
Sorry dwightc now power buttons are not available for your model but one solution is there. you can find a suatable rubber buttons in the stores you can match it
Tanx
Take Care
Bye
Ilo mp3 player
No - they are out of the mp3 business. Wal-Mart is your best shot.
Jan 24, 2008 | iLO (2 GB) MP3 Player
ILO wont work
One of two things..try a new battery...or it's possible that your button lock button is in the lock position ( look under the power button make sure it is pushed up)
Dec 24, 2007 | iLO (2 GB) MP3 Player
Help
Company no longer supports
Sep 27, 2007 | iLO (2 GB) MP3 Player
My ilo mp3 won't turn on
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Sep 23, 2007 | iLO (2 GB) MP3 Player
ILO MP3 PLAYER WON'T TURN ON
If the Mp3 isn't starting try seeing if the "hold" button isnt on
May 25, 2006 | iLO MP3 Player
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
