CANNOT SET UP SCANNER - Office Equipment & Supplies
  • 1 more comment
  • gram7 Oct 20, 2008
    Can not set up scanner..
  • kespiroff Nov 13, 2008
    HP7410 control panel set up menu will not activate scan mode
  • Ajana Jan 30, 2009
    Installed Scanner Driver epson12688 from epson.com .
    But nothing happened. The self-extracting file did not seem to "really: install anything.This is on WinXp SP2.
    Any help or pointer is appreciated.
    Printer is working but not Scanner.
HP Officejet 5510 All-in-one
1.) No Scan Options is coming up when I press scan
2.) Will not print from the computer.
3.) Copy is working on the HP
4.) Fax is working on the HP
Posted on Feb 04, 2009
How do I get a scan count on this device
Hi Dwayne,
You can view the scanner counter as follows:
For Windows XP:
1. Turn the scanner on connected to your PC. Open My Computer, right click on the displayed scanner model
2. Click Properties, under the "Device set", you can see the total page count.
For Windows 7:
1. Turn the scanner on connected to your PC. From the "Start" menu, click on "Devices and Printers"
2. The scanner model is appered in the window.Right click on the displayed scanner model
3. Click 'Scan Properties', under the "Device set" tab, you can see the total page count.
Thanks & regards,
ScanCare
Nov 30, 2011 | Fujitsu ScanPartner 15C Flatbed Scanner
I need to see the scan counter
Hi Dwayne,
For Windows XP:
For Windows 7:
Thanks & regards,
ScanCare
How do i set the scanner to only scan dedicated channels
Here http://support.radioshack.com/support_electronics/doc69/69887.pdf is the manual to your scanner.
It appears that all you should have to do is press the SCAN button and it will start scanning your programed frequencies.
May 19, 2010 | Radio Shack Pro-82 Scanner
Batteries run down in a little over half a day in my new uniden BC72XLT scanner, is it batteries, charger or scanner?
its most likely the scanner. i had one that used up batteries pretty quick. my advice would be to get rechargeables, and get 2 sets of batteries so when one set runs down you can put the fresh set in the scanner
Jan 13, 2010 | Uniden BC72XLT Handheld Scanner
Set up scanner
install software then restart the computer , once restarted plug the scanner in the computer and wait for it to see the scanner then after you should be able to use it
Oct 05, 2008 | HP Office Equipment & Supplies
How do i use an inherited uniden scanner. dad didn't leave instructions.... how do i set it up? which frequency do i use? many thanks
A scanner, if used properly, can monitor frequencies as it progresses through them. If you want your scanner to monitor only certain frequencies of your choice, you can set those frequencies as the PRIORITY channels. Example: push PROGRAM then punch in frequency 152.6255 then set the mode (if nessessary) at VHF (very High Frequency) UHF (Ultra High Frequency) or FM (Frequency Modulator) or AM (Amplitude Modulator) etc. You can program as many priority channels as the scanner allows.
Hope this helps!
Jun 23, 2008 | Uniden BC72XLT Handheld Scanner
My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Oct 03, 2007 | Metrologic Instruments 9520 Voyager
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
472 people viewed this question
k24674
jasbo
jasbo
