Well you can please follow the below steps - 1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open. Please post comments if you need more help or information..........
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dispenser may be bad. Push the hi-temp button , air -dry, hi-temp, air-dry in that order. All lights will lite up and this will do test cycle of all components. If soap disp opens then soap tab may be the issue. I have had intermittent dispenser issues and they are often hard to solve as other components may be at fault.
It sounds like the soap dispenser flap is stuck or the latch is broken. Try to see if it can be manually opened to loosen it. How long do you wait before starting the dishwasher after the soap is placed in the dispenser? Check and see if the cover opens even a little during the wash cycle?
There could be a problem with the solenoid that opens the soap dispenser. I don't know of the part number for this. You'd have to call Bosch or check their website.
