Question about Toshiba 32A33 32" TV
Toshiba 32A14 horizontal line
Hi-
We have the dreaded horizontal line on our screen. I've read some of the other posts on this matter and wanted to know if it's worth repairing. I don't have any experience with this stuff and I'd only screw it up more if I tried to do it.
As long as everyone agrees that the horizontal line is some vertical failure or capacitor problem, I think that is what has happened.
BTW, it's actually a 32A14 tv set, not a 32A33 set.
Thanks
FJT
  • 2,071 Answers
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 25, 2008
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Lcd tv horizontal lines
This problem and solution were posted previously. The following is the link:
http://www.fixya.com/support/t7775296-model_55sv670u_screen_horizontal
Dec 25, 2013 | Toshiba Televison & Video
Black horizontal lines across entire screen.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Dec 08, 2012 | LG FLATRON W2252TQ-PF 22" LCD Monitor
It is a 32A14 model. power to house was cut off, electric people replaced phone poles. when power came back on tv wouldn't turn on, no red LED indicator light lit up, and it makes this chirping sound in...
The tv high voltage "H" horizontal transistor IC is dead.That "H" transistor IC sit out side outer wall of the FBT-the flyback transformer,that the big black block of a plastic,with a red wire with a cap hook up to the CRT-(tv tube).Best take to the shop for repair,because part for analog tv are impossible or near impossible to find and do for the replacement.
Mar 14, 2011 | Toshiba 32A14 TV
Where are fuses on Toshiba 32a14 TV won't turn on
The fuses are located on the inside of the set, remove the back cover and follow the power cord in, there should be a main ac fuse near the cord on the circuit board. Toshiba usually has a second fuse further up the power supply.
Feb 21, 2011 | Toshiba 32A14 TV
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
I have a 32A14 Toshiba TV. At full screen, the
you have to take in affect on how old is the tv if you have had it a few years then the screen is going out and will only be a matter of time before it goes all the way out and you will be buying a new one if it not old and its one of the newer flat panels then its the signal that the tv is receiving if its hooked to a digital antena then you only get max of 720 from it on certain channels no matter if the channel or channels are showing hd with out a hd source your tv will not show better then that i have a 42 inch hd flat panel and use a antena and the best i get from my hd broadcast channels certain times will i get true hd like when the news is showing or when one of the series that was filmed in hd is on other then that i only get a 720 picture instead of a 1080 most commercals are not film in 1080 but in 720 max and i dont know why makes no since
Aug 28, 2009 | Toshiba Televison & Video
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Tv will not turn on
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Toshiba 32A33 32" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Toshiba 32A33 32" TV Logo
259 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
