Question about Panasonic Televison & Video
Panasonic Model DMR-EZ48VK COMBO VCR/DVD RECORDER When I put any disk in, it has started making a 'grating' sound for a few seconds after the door shuts. Now it has begun to occasionally misread partially recorded discs, saying there is no blank space left when I know there is! It seems to be getting more frequent.
  • 5 more comments
  • Pynblackcat Aug 20, 2008
    This is not a computer dvd. I'm recording programs off TV and have been doing so since I bought the thing. I know when I have blank space on a disk.
    No error codes. If it misreads the blank or partial blank disc as full, I open drawer, then close it again. Most times it corrects on 2nd try, sometimes takes 3. Could the problem be the laser dirty? It has no trouble recording.
    Bought machine brand new in December 2007 or January 2008.
    If the laser has gotten dirty, what's best & safest cleaning solution?
    Clean laser with what? Cloth? Solution?
  • Pynblackcat Aug 21, 2008
    No other disc stuck in it. After I blew into it, it doesn't do like it was. I think laser 'eye'? was dirty. What's best way to clean? Compressed air? Dvd cleaner disk?
    Yes, it appears lens was dirty and couldn't always read discs correctly. It also stopped making that 'grinding' noise, which must have been it trying several times to read
  • Panasonic Master
  • 19,396 Answers
  • 6,487 Answers
This can be a dirty lens of your player, try running a CD cleaner to clean the lens, then try it again hopefully that will fix the problem..
Hope that helps..........
Posted on Aug 20, 2008
  • Mark Gil
    Mark Gil Aug 20, 2008
    Use a CD cleaner to clean the lens,, you just need to run the CD cleaner to your player.....
  • Mark Gil
    Mark Gil Aug 21, 2008
    Use a DVD cleaner that is the best way to clean it...
    Master:
  • 623 Answers
Just take it to a pro....
has something to do with the rails
good luck
    Champion:
  • 221 Answers
In regard to the grating noise: I have a Toshiba DVD/VCR player. A DVD was once put into the loading tray, and got stuck in the player. Is it possible that the DVD is rubbing against another disk that is jammed inside the player?
Another possibility is that the spindle that supports the disk is lopsided or bent in some way that doesn't allow it to be read.
As poormanjoe83 said, you need (regardles of +/-) RW disks to "re-write" or add data to a disk.
    Master:
  • 638 Answers
You have to open the dvd player.and just clean the lens of it.and tighten the screw of the tiny motor inside.the sound is because of loose motor screw.and the lens are not clean so its partiall reading and giving incorrect messages on the screen that there is no space in your cd.the unit is perfectly alright and it will definately work.just do it.
    Master:
  • 521 Answers
Servicing the machine is the simple solution.you yourself can do.or take it to the service center.
  • tech expert12 Aug 21, 2008
    clean with alcohol and use tissue paper.
  • 4,472 Answers
How long have you owned the machine and how much have you recorded on it. These machines do wear out. you have the options of getting it serviced or replacing it.
if you need any further assistance please let me know.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 21, 2008
    If you want to attempt to clean the lens you would buy a dvd/cd lens cleaning kit which can be picked up at any electronics outlet and also wal marts. If you need any further assistance let me know. If you found this helpful I would greatly appreciate if you could accept and rate the solution accordingly.
    Thanks,
    Lee
  • 928 Answers
If you hear grating sounds that means that there is something misaligned on the DVR. Normally with panasonic you should also get an error code on the screen does one come up?
  • Thomas Lim
    Thomas Lim Aug 20, 2008
    Its doubtful that it is the lens since you hear a grating sound most often it has to do with the gears. I would suggest you take it to a repair center. Although another option is to open the DVR then try to play or run it and listen where the grating sound comes from
  • 35 Answers
You cannot add extra data to a DVD-R. Are you using DVD-R's to record?
How to fix code F60 problem?
Defect of Digital P.C.B. processing board and needs to be replaced. F60 is a result of a low or missing voltage on the digital board. Often the culprit would be capacitors that have leaked.
But first try a "cold boot". Unplug the device, wait 2 minutes, then plug it back in. When the 00000 display starts, hold down the POWER button for at least 10 seconds which puts the device into "standby mode". Wait another 10 seconds then press the POWER button.
Aug 13, 2015 | Panasonic DMR-EZ48VK DVD/VCR Combo DVDR/RW...
Manual for my ram dvd player dmr-ez48v
Panasonic has the owner's manual for the DMR-EZ48V on their product support page. Go to http://shop.panasonic.com/shop/model/DMR-EZ48VK and click on the Owner's Manual tab (second from the left). The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/DMREZ48V-MUL.PDF . (Note: this is the US version of the DMR-EZ48V.)
I hope this helps.
Oct 18, 2014 | Panasonic Dmr-e20 Dvd/ram/dvd-r Recorder /...
Panasonic VCR/DVD combo - stopped recording sound
Seek tech support. This is not a self repairable work. Need technical skill.
Jun 02, 2012 | Panasonic DMR-E75V DVD Player/VCR
White colour displaying as pink on DVD recorder DMR-EX77EB, problem just started a few weeks ago.
Very similar problem with my DMR-EZ27. About 10 minutes into playing back a DVD the color starts going away until I only see a black/white movie. Sometimes color comes back in partially then back to b/w
Feb 13, 2011 | Panasonic DMR-EZ48VK DVD Recorder
When I place a dvd in my Panasonic DMR-EZ47V DVD Recorder / VCR Combo, it apparently does not ''sense? it and indicates it ?no disc?. Any Suggestions?
hi, make sure you read the manual' to use the right disc.some can only record on few brand disc's name's only.hope that help.
Feb 20, 2010 | Panasonic DMR-EZ47VEBS DVD Recorder / VCR...
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES35V
I have a dmr-ez25eb DVD recorder and it has stopped Recording and playing back , the screen on the TV says that its a none recordable disc but I have been useing them from the time I purchased the DVD
Aug 31, 2008 | Panasonic DMR-ES10 DVD Recorder
VCR, DVD PLAYER
Try resetting the unit. Push and hold the on/off button for 10+ seconds. --or-- Look for a reset button behind the drop down door, and gently depress it with a pen point for a couple of seconds. If this does not work, try calling Panasonic.
Apr 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
179 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
