you should be able to calibrate the touch screen.
You can calibrate the screen so that your phone
recognises the input better.
1. In Menu mode, select Settings → Phone
settings → Calibration.
2. Tap the target on the screen.
3. Select Yes.
hope this helps.
try reseting it with holding down the menu and center button. Your warrenty will have been voided due to the liquid damage though so if you cant get it working with the reset your gunna need a new one.
your phone is being reset if the situation is like that. get your pen and push the button beside the charging socket and press the power button also simultaneously.
2 Suggestions:
1) It may be that the battery isnt charged, let the unit charge fully
2) If that doesnt work, its probably time to send the unit back to sandisk
Have you tried to do a reset? Toggle the hold button on and then off. Then hold down the menu button and the center button at the same time. hold them until the screen flashes. then release. You may have to try this several times.
umm im not sure if this will work but you could try holding menu center button untill the apple comes up (this may not work if ipod has not got any power to run)
hi
this meens the wohle panel is squashed on its buttons
the seek button is main 1 and wont let anything work besides it
take out the button
release the screws all the way
jiggle it a little bit, or even take a look inside that nothing is broke or loose
tightened the screws but not hard(soo it wont happen again)
good luck
