Question about Cameras
I have a Canon EOS 3000. No LCD display. Cannot check batteries. Camera seems 'dead'. However, will camera 'spring to life' only once film has been loaded ?
Silly me. All the camera needed was new batteries. Strange though that even although batteries still had some life in them, it wasn't enough to tell me that I needed new batteries.
Posted on Sep 01, 2008
I need to conect my camera eos 3000 to the computer what i need?
The EOS 3000 is a film camera and was not designed to connect to a computer.
Oct 10, 2012 | Canon EOS 3000 Kit 35mm SLR Camera
Canon eos 500 not working
have you tried with another film
Apr 28, 2008 | Canon EOS 500n 35mm Film Camera
Canon EOS 300x battery problem: it doesn't work, even with fresh batteries. The LCD battery indicator blinks as they we're dead.
First make sure the batteries are in the correct position/orientation clean both battery terminal and look down inside the battery compartment make sure the "lower" connection is clean (shinny) if not you may need to use a pencil eraser with a piece of sandpaper affixed to it to get down in there and scrub off the corrosion. Another thing and I've run into this myself on a Canon Elan IIe was the battery indicator showed new batteries as dead but the camera attempted too function so, I just used it and used it and withing a few minutes the battery indicator showed the battery state of charge more accurately.
Mar 04, 2011 | Canon Photography
My cannon eos 500 wont take a picture it just displays empty battery
canon eos500 cannot use LCD screen on auto focus mode - the screen will only display menu setting
Nov 23, 2010 | Canon EOS 500n 35mm Film Camera
The camera back button requires power to operate and as the electronics seem to be fried button pushing doesn't open the door. So is there a manual access way? thanks
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
Nov 08, 2010 | Canon EOS Elan IIE 35mm SLR Camera
Canon EOS Digital Rebel XT: The upper lcd screen info flickers,some of the icons on the screen work normaly, but other icons are lighter and flicker. Im speaking about the portion that displays battery...
It seems you have a false contact in the upper LCD screen, its flat ribbon cable or the connector at the main board.
It is necessary to open it and check it.
It is fairly easy to do it, but if the camera has a warranty, I do recommend you to make it valid.
If does not have warranty, then you may try in do it yourself if you have some experience and skills to fix electronic devices, or pay to have it done.
Best regards,
Jun 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Eos Rebel 2000 battery problem
Send camera to me and I will advise you B4 repairs regarding cost etc. WWW.FLCAMERAREPAIR,COM Art Schneider
Oct 18, 2007 | Canon EOS-AE-1 35mm SLR Camera
Pictures captured by my camera are not complete
your cmos sensor might be dead. try taking it into canon for repair.
Sep 04, 2006 | Canon Digital Rebel / EOS-300D Body only...
Cameras Logo
64 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
