Question about JVC AV-56WP30 56" Rear Projection Television
No sound from TV
You can turn on my TV,but there is no sound how do I fix that?
  • msltrujillo Dec 10, 2008
    my picture is green and one day I turned on the tv and there was no sound and the volume is up. I've checked all the settings in the menu and everythings seems fine. ??
  • 70 Answers
Im not quite sure of your exact situation but you can go into the menu and make sure you have the audio set correctly or check the cables inthe back. you can also check the settings on your equipment to make sure you are outputing the audio in the correct manor
Posted on Sep 21, 2008
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
Jan 21, 2016 | Televison & Video
MY PICTURE IS GREAT,BUT NO SOUND. WHAT CAN I DO TO FIX IT?
Make sure TV is not muted.Make sure the TV is not set to SAP (secondary audio protocol)Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.If using an "S" video cable into an input on the back of your TV, these cables carry no sound, just video, so make sure you connect an audio cable too.Hook up an external device to the "TV audio out" input. This will be the test to see if it is a TV circuit board malfunction or the speakers are faulty in your TV.If you are connected to a satellite box, use the included remote and go into the "menu". Check to make sure sound settings are set correctly.
Read More: http://removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/#ixzz3lTeW6isH
Sep 11, 2015 | Televison & Video
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
L32W861 Black Screen.
Buy THIS main board, and replace it. Most of the time, this should fix your no picture, no sound issue.
Jan 31, 2013 | AOC L32W861 32 in. LCD TV
Tv turns on but makes an electric cracking sound and shuts off another one turns on then the screen wigs out and turns off with the power light flashing
Try to unplug tv from the power source for 2-5 minutes and if still have the crackling sound it means the tv needs to be fix. So check your tv's warranty and call the tv's manufacturer to have it fix or replaced.
Sep 09, 2010 | Philips 32PT6441/37 32" TV
No sound on sharp tv flat screen model LC when turning on again
we fixed the problem, no further assistance required
Thanks
Feb 16, 2010 | Sharp Televison & Video
I turned on the DLPtv it made a weird sound and nothing happened.
Sounds like the High-voltage went out on the TV, probably have to replace TV
Aug 22, 2009 | RCA TruFlat 27F520T 27" TV
Red power light flashes. tv won't turn on.
how old is your tv?? ours was 2 1/2 yrs old it was a 40in lg hd ready lcd tv it just crackled and turned off one night same as yours it would turn on but with no picture or sound....we took it for repair and they said it was something inside that is basically impossible to fix...it would have cost more that the tv itself. BUT trading standards say a brand new tv should last upto 3yrs...you need to get a free qoute nd if they cant fix it contact trading standards and the tv MANUFACTURER not the shop where you got it....you NEED a reciept to do this for proof of when you purchased it...hope this helps :0)
Jun 29, 2009 | Televison & Video
Turn on tv get a white screen and no sound.
I had the same problem and got a TV repair man to fix it for real cheap. The whole fixing took less then 30 min and he goes to your house to fix the TV. He fixed it for an excellent price that left us astonished. He lives in NY. Email me if anyone needs his contact information. You wont be disappointed.
Mar 15, 2009 | Polaroid FLM-1911 19 in. LCD Television
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
Dec 27, 2008 | Curtis CM32020S 32" TV
JVC AV-56WP30 56" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
