Nakajima AX-150 Typewriter Logo
Posted on Jun 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW CAN WE REPLACE CORRECTION TAPE IN Nakajima AX-150 Typewriter???
  • Anonymous Mar 17, 2014
    NAKAJIMA AX-150 REPLACE TAPE
Dick O Reilly
Level 3:
  • Nakajima Master 3,594 Answers
  • Posted on Jun 13, 2011
Dick  O Reilly
Nakajima Master
Level 3:
Answers
3594
Questions
Helped
609218
Points
6852
Go to NADIST.COM, click on current models you will find a manual there.
DickyO
Nakajima AX-150 UK to USA transformer
The Nakajima AX-150 Typewriter requires a step-down transformer to be used in the USA, as the UK operates on 240 volts AC and the USA operates on 120 volts AC.
To determine the size of the transformer needed, you will need to check the voltage and amperage rating on the typewriter's power supply or label. You can then use a transformer with a matching or slightly higher voltage rating and at least the same amperage rating to ensure it can handle the load of the typewriter.
It's always best to consult with a qualified electrician to ensure you are using the correct transformer for your specific situation and to ensure safety.
How to replace the ribbon and correction tape
Take a look at how the old ones are installed and replace with new ones.
1helpful
It's totally messed up, is there anything I can do?
Remove the print wheel,look for bent of broken spokes, be sure the correction tape isn't getting into the P/W.
DickyO
My type writer not work properly its problem is it is starting from left to right and no coming letters only coming symbols
Be sure that the correction tape is the dry type, remove the printwheel and check for bent or broken spokes.
DickyO
Can I get the user's manual for typewriter NAKAJIMA AX-150 model, please.
Hello.
Although I couldn't find anything online, call Nakajima at 1-800-809-7138 for info and support.
Hope this helps.
2helpful
Can not find the way to ( ' ) and ( ! )
I am not personally familiar with Nakajima AX-150 it’s been over a year since I have seen one. First do you see those characters on the keyboard? If you do but get a different character when you type it? If so, then you likely have either a non-OEM printwheel or possibly a non-English language printwheel. As you see from the samples below every Nakajima brand print wheel has both on those characters.
I have included the link if you have trouble seeing the type faces.
http://www.granadahillsbusinessmachines.com/items/supplies/typewriter-supplies/nakajima-typewriter-supplies/nakajima-printwheels-detail.htm
1helpful
Correction tape not working on this model
This T/W has 2 tapes a black ribbon and a lift off tape the L/O tape has to be a tack free type General Ribbon T355 or equivelent. It installs below the ribbon on the left and feeds to the right.
Correction Tape
They just snap off by pulling them by the spools.
Top Nakajima Office Equipment & Supplies Experts
Mitch Vass
Mitch Vass
SmartAviator
SmartAviator
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
