I am trying to connet a new printer and it say it will connect actomatically when usb cables are connect. I have already connected the cables and nothing is happening.
  • 114 Answers
Did you install the drivers before you plugged in the printer? Usally the driver install will tell you when to plug in the cable.
Posted on Aug 19, 2008
I need to connect my canon iR2016j with my windows 7 PC , my computer can not identify it as USB connected hardware
Make sure the printer is Windows 7 ready, if so read the manual carefully, some of the printers software must first be installed before you can put the power on and connet the usb cable, i suggest you uninstall the printer and follow the instructions carefully
Dec 11, 2010 | Canon iR 2016i Black and White Copier
When i connet the usb then the usb device not recognized command appear the system.
hi try to connect it with another usb cable. the cable can be deffective
Oct 26, 2010 | HP PSC 1410 All-In-One InkJet Printer
When connected to computer, displys
please install the drivers first and then try connecting
Mar 07, 2010 | HP LaserJet 1020 Printer
Hp j3680 was installed but now it cant be recognised on the usb port.
Check your USB ports and cable. If you have the unit plugged into a hub, try directly connecting to the computer. (A bus-powered hub is at higher risk but failures are known with both.) Try swapping to a new port (if you are already directly connected to the computer). Check if a known working device works in the port. Ports can burn out under some situations.
Try a brand new cable as well. In some cases, you might want to try unplugging the power connection as well as the USB cable to clear any issues on the printer.
I hope this helps.
Feb 08, 2010 | HP J3680 Officejet All In One Printer
Where do you connect the usb cable for printer to computer.
Does not matter which one, they are all the same. Just plug it in to the least accessible one so it will not be in the way.
Aug 08, 2009 | Lexmark X2250 All-In-One InkJet Printer
How to connet to the computer and how to find drivers
If your printer has a "Centronics" printer connection (a large 2"wide connector) and your computer has only USB connections, you need a "USB to Centronics" printer cable. Easiest way is to buy one from the internet. Use your favourite search site or EBay to locate and purchase. Most computer stores will not have them in stock.
Jun 27, 2009 | VeriFone 900 Printer
Can't re-load hp photosmart 7150 on windows xp. Gets to the point where the installshield should come up, lingers awhile, and then says check printer power and usb connection. The computer has already...
1.It could be the USB cable. Try a new cable.
2. Could be USB port, use another if available
3. You should be able to install the software without the printer connected.
4. Uninstall all hp printer software, and restart computer.
5. Delete any instances of the printer from the printer/fax located in control panel
Apr 15, 2009 | HP PhotoSmart 7150 InkJet Printer
How can I install a printer to my Compaq. There is no port !
Newer printers will have a usb connection so u will need to buy a usb cable to connet between your laptop and theb printer. Alternatively, if your printer is old and doesn't support usb then you will need to buy a parrallel port to usb adapter to allow you to print from your laptop. With printers so cheap these days its actually more economical for you to buy a new printer rather than the adapter.
the only other way to do it is to connect your printer to another computer and share that printer over the network and then you can install that printer on your laptop as a network printer and therefore print from your laptop.
good luck
Feb 20, 2008 | Compaq Presario 700 470024-192 Notebook
