Question about KitchenAid Microwave Ovens
Need to remove kitchenaid microwave model kemc308ksso door to replace spring
  • KitchenAid Master
  • 8,865 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 21, 2008
How to change the torsion springs in my kitchenaid microwave oven KEMC308KSS01
Replacing the spring isn't very difficult if you're mechanically inclined.
You're basically removing a few screws, the front panel of the door is removed exposing only the glass part that's still hinged. The springs are exposed. Hopefully one spring is still in tack so you can see the orientation of how to put the replacement in. It's not very intuitive on how to do this part.
Check this link for more details:
Microwave Repair
Feb 12, 2015 | KitchenAid Microwave Ovens
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
Jan 25, 2015 | KitchenAid Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Latch opener spring broken wont open door
You can buy a new door spring through KitchenAid by calling For more information on warranty replacement, please call 800-541-6390
that should solve the issue if not feel free to contact me.
Jan 29, 2011 | KitchenAid KCMS145J Microwave Oven
How do i replace the door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find handy exploded views and order parts by model number here.
Dec 31, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The door press opener button of my kitchenaid
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, usually only the control panel needs to be removed.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Nov 27, 2009 | KitchenAid KCMS185J Microwave Oven
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Dec 24, 2008 | KitchenAid KHMS147HS Microwave Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
Aug 19, 2008 | LG MV-1444Y Microwave Oven
Kitchenaid microwave/oven combo model KEMC308KSSO
The keypad circuit board must be replaced to start. Sometimes, the fault can also be on the main processor board.
Jerry G.
May 15, 2008 | LG LMV2055ST Microwave Oven
Microwave Ovens Logo
382 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
