Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Blue screen sony
My 46WT500 sony now has a blue screen, then turns off.
the power went off last night while watching TV, power came back on, TV came back on then faded to blue and turned off.
Any thoughts?
ThanksPaul
Blue crt shorting use crt restorer to lift short or replace picture tube /crt
Posted on Sep 03, 2008
Blue screen need to know how to scan channels to get input to come back up
Will need to know what tv you have, but you are right it is probably your input button. if you pushed it on your remote then there should be an input button on remote. otherwise you will have to go into the tv menu and setup it up there.
if you respond with model and make of tv, might get more info.
Jul 12, 2012 | Polaroid Televison & Video
Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
1800-222-SONY
I hope this help,
Skyassoc
Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
BLUE SCREEN My sony KP 46wt500 hdtv ready rear projection has
Ur tv have a problem known as convergence problems.Ur tv convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
Jun 06, 2010 | Sony KP-46WT500 46" Rear Projection...
Screen turned solid red, and tv shuts down . worked fine last night.
Most likely cause of that is a red CRT has shorted which will shut the set down.
Mar 04, 2010 | Sony KP-46WT500 46" Rear Projection...
Screen turns green and tv powers off.
visit your local service center. you cant do anything more up to this point
Jul 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Clicking on Blue screen appears then shuts off
The problem sounds to be in the power supply board. May also be a horizontal drive problem. Sorry I can't be of more help, but there are may voltage problems ( shorts, open capacitors, bad chip etc ) that couls cause this problem. The reason the set turns blue when it first comes on is that it doesn't have time ( or can't find a signal and the screen default to blue. Wished I could help more.
Ed
NC Electronic
Mills, Wyoming
Dec 25, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KF-50WE610
the color drive is going bad check with the sony service center it might be cover and repaired free.  my set went blue and the service tech is checking if it is covered.  good luck.
Sep 30, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
