Question about Canon imageCLASS D661 Digital Printer
Ghosty copies When making copies, all of mine are coming out ghosty...with previously copied words on top of the new page. HELP!
  • winninge Dec 09, 2008
    My copies have black streaks down the center of the and the words are copied twice, once correct, and the other like faint images
  • 35 Answers
On the printer you need to go into the settings and run "calibrate printers"
Posted on Aug 19, 2008
HOWDO I ALIGN GHOSTY PICTURE ON PHILIPS 40PFL5570H/12?
The second half is technical heavy for some ppl and you might want to think about getttin a new tv or pro.
Feb 14, 2015 | Philips Televison & Video
Docucolor 12
check scanner unit which hit the opc drum, may be hide by something
Dec 27, 2013 | Xerox DocuColor 12 Color Copier
Problem with color monitor BenQ G900W лblack tsvyan almost gone? and the predominant red hue! how to fix it
BenQ 19" monitor GENERIC pnP lcd
displays upper part (a 12 cm wide band) lighter than the down part which is normal
the cursor when in the lighter part becomes ghosty and very white
Oct 27, 2010 | BenQ G900W Monitor
I am having a old Samsung SAMTRON 55V (15") MONITOR. Now I isnstalled a logitech web cam. The image is not showing properly. Ghosty picture. Pl. help.
look dear ,,your monitor is not compatible to the video output of your web cam,,,,so you have either have to replace the monitor or your web cam...but problem is that if monitor is very aged then you won't get cam compatible with it...
Oct 21, 2010 | SAMTRON 55V 15" CRT Monitor
Picture is ghosty. Magic focus doesn't fix the problem.
Replace the STK ICS They are big Black ICs will have PN# on them STK392-110s use 120s
Mats Electronics has them 1-800-628-1118
Oct 04, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I don't know how to copy two pages (size A4) at
open the photo copier put the original copy on top of the screen words facing down then cover the machine then press copy then ok after it will copy, after remove the copy from the photocopier then pull the tray and put that copy on that tray the words copied facing up then put the tray back then open the upper side where you put the original copy then change it to another side, cover the photocopier, press copy then ok it will copy on boss sides.
Jun 10, 2009 | Canon iR 1600 Laser Photo Printer
Printed copy in correct page order- HP officejet 6110
Hi :)
This may work and its only a few simple clicks :) but it will take less time then re ordering you pages :)
IN the printer settings or Print preferrences there should be a tab for "Advanced settingings"
Go to Control Panel and select "Printers"
Select the general tab and at the bottom of the window select "PRINTING PREFERENCES"
another window will open
from here select the Advanced tab
Find Layout Options in the list
click it you should see "Page Order" and a drop down menu for front to back or back to front.
switch it to whatever order it is that you need and test it out.
or if that doenst work try this:
Set the most frequently used copy settings as the default. This includes changes to Copy Setup options in the menu system, as well as other front panel copy settings.
  1. Make any desired changes to the copy setup from the menu or the front panel copy option.
  2. Press Menu .
  3. Press 1 , then press 4 . The settings are now saved.
these are the only ways I have found to correct the problem.
May 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Samsung HCL473W 1080i red shadow & words are curved at top/bottom
I believe you have convergence problem on your rear projector TV. It require to replace may be 2 IC output convergence or the convergence drive, after replace those component you need to readjust convergence which mean you move the RED GREEN BLUE to be 1 on top each other you must have the remote control and service manual to get into the service mode, if you thing you can get those part in your country the service manual I may help you with that, ask your husband if he like to challenge it. I hope that is give you some ideas
Cheers
Dec 17, 2008 | Samsung - Projection TV replacement lamp...
Color copy quality
I have a hp psc1210 all in one printer and a linksys wrt54g router.
Is there any way I can use the printer using the wireless mode. Thanks.
May 07, 2008 | HP Photosmart C3150 Printer
Canon imageCLASS D661 Digital Printer Logo
75 people viewed this question
old marine
old marine
