Question about SanDisk Sansa e200 MP3 Player
Sansa e270 synchronizing problem
My sansa has been working good for 2 years and suddenly it has stopped working. When I try to sync it to my computer it begins to sync the first song and when it its 100% it says error and moves on to the second song. Halfway through syncing the second song it freezes and my Sansa screen either freezes or turns white. I have tried formating it multiple times and have updated my firmware with no luck. I can still add videos but music is my big problem.
  • 758 Answers
It might be a device certificate error..what you will need to do is to format the device..Keep in mind that formatting the device will delete all the songs you have in there..to format click menu,settings and then click on format..if that doesnt work you will have to update the firmware on the device...Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
I hope that helps
Thank you
Computerrep
Posted on Aug 20, 2008
I can not resync my sansa e270 when i plug it into the computer, i use rhapsody and never had this problem before
Hi, theres 2 ways usually to sync with sansa.
usually wen u plug it into the usb cord, u shud be able to open a folder and put musik through that.
My computers. than go to Sansa
or WMP depending on ur version
go to Synchronizing or Copy to CD or DEVICE.
there should be syncing button under the music list depending on the version.
but i stick to open my computer and the Sansa folder.
IF NOT THAN DO THIS..
Go to ur Sansa in the USB option change it to MSC than follow these instructions
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the drive for your Sansa.
3. click on Tools choose File Option, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
Good luck.
Mar 12, 2011 | SanDisk Sansa e270 MP3 Player
Windows media player does not recognize the e270 when I connect it to the computer. It continues to ask me to connect a device to sync.
Sansa gives the next answer for the e200-series: The device appears properly in Device Manager and My Computer, but is not recognized in Windows Media Player and cannot be synced. STEP1 - Download the appropriate hotfix from Microsoft
  1. Download the hotfix from http://support.microsoft.com/kb/939211
  2. Run the hotfix.
  3. Connect the device to the PC.
For other Frequently Asked Questions (FAQS) go to
Sansa support:
http://www.sansa.com/support/sansa_e200/faqs
Aug 21, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270
Try Refreshing it then Format it if that does not work cal Sansa tech support for your area. The number is on their website.
Apr 17, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 it lost driver
Go to Sandisk's website and get the software you need. If the reinstall fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 21, 2009 | SanDisk Sansa e270 MP3 Player
My sansa e270 6gb is frozen and wont go past the refresh database screen what can i do to erase all the data that is on it and start all over
I'm always hesitant to give this answer, because if it's done wrong, you can do more damage to your player, but the answer is: you need to format your player. I would format the player from inside the player's settings menu - but if it's stuck on Refresh database, you may not be able to do this. Follow these steps in order:
-Tha Mp3 Doctor
Feb 15, 2009 | SanDisk Sansa e270 MP3 Player
Format my Sansa e270
1 way is to let windows re-format it.
Plug player into usb of computer.
open up mp3 drive. click on tools.
have windows re-format it.
2. Download firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1449
download the new firmware and check the box that says reformat
data area.
Jan 04, 2009 | SanDisk Sansa e270 MP3 Player
Sandisk e270 !!!!!!!!!!!!!!
hi sir..
if ur are formated the memory card..
1. memory card may be corrupted.
2. try to restore the factory settings
a) by tool>setting>phone>general> restore factory setting's or other option like install. thank u sir..
please fix it.
Sep 03, 2008 | SanDisk Sansa e270 MP3 Player
E270
The database is corrupt or the licenses on the songs expired - Sansa had a fix on their website, but they took the software down in the last 3 weeks - I would go ahead and give them a call
But, first, make sure you tried everything:
-Tha Mp3 Doctor
Jul 06, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270
The song does not have transfer rights - you must upgrade to Napster To Go.
Jun 21, 2008 | SanDisk Sansa e270 MP3 Player
E270 sansa
-Tha Mp3 Doctor
Dec 12, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
78 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
