Question about HP LaserJet 4 plus Printer
13 paper jam but no paper in printer: laserjet 4 plus
  • HP Expert
  • 141 Answers
Possible tray sensor flag, broken fuser sensor or tray 1 sensor. good luck!
Posted on Sep 14, 2008
I have a laserjet 4 plus. i'm getting error 13-paper jam. need help. no paper is jammed up in it..
There will be something in there, whether it is toner/ink over a sensor, a paperclip/staple, or a tiny scrap of paper.
The trick with this one is patience, methodically strip it down as far as you can, checking as you go for stuck material, and once you have gone as far as you can put it back together nice and slowly, looking for broken connections and loose bits, then try it again.
If there is nothing in there then the printer has something broken and needs looking at by a technician, in this case you should turn to your warrenty.
Oct 29, 2010 | HP LaserJet 4 plus Printer
13 Printer Jam Problem
If it is jamming under the toner (meaning the paper is not quite reaching the toner cartridge, and "crinkling" up), then you would be correct. There may be a tiny pipce or chunk of paper creating a "well" and stopping the paper. If you remove the paper tray and the cartridge, and flip the machine on it's back (fuser side), you may be able to see the chunk in the paper path. You could also get a sturdy pice of laminated paper or card stock, at least an inch or two wide, and run it backwards thru the path to try to back out the chunk.
If the paper is just stopping, in any other spot than the paper tray, it could be a dirty or dead sensor. Try removing the cartridge and spraying canned air throughout the machine.
Apr 21, 2010 | HP LaserJet 4 plus Printer
Paper jam 13. no paper jam what can i do?
One of the paper sensors have activated/faulty. locate HP service center to help you check it out. You require a technician to assist you solve this problem.
Dec 29, 2009 | HP LaserJet 4 plus Printer
Paper Jam
maybe there is more than 1 piece of paper jamed
Jun 29, 2009 | HP LaserJet 4 plus Printer
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual: Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
Rollers do not turn on!
Rollers are driven by a motor.
How is the printer telling you this information? (does the PC give an error, or the printer flash lights)
Does the paper make it out of the machine?
Is this "Rollers in the Back" the Fuser Unit?
is The Fuser unit is going bad,
if you open the back top cover, where it gets real hot, where the paper exit's, you should see two rollers, one orange, one either brown or black.. if that orange roller is damaged, has crease's, or covered with black toner, if the paper jams here alott, you probably need a new fuser unit. there is a pm kit available which includes the fuser and rollers, transfer, etc, which this site might have
Oct 23, 2008 | HP LaserJet 4 plus Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Paper jam
Does it show anything after 13?
Oct 19, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
199 people viewed this question
Ben Johnson
