Question about Maytag MMV5207A Microwave Oven
Broken handle the bottom of the handle broke, can the door come apart?
  • Maytag Master
  • 9,174 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 21, 2008
SOURCE:
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
The bottom of the door handle has broken loose. There doesn't appear to be screws on the inside of the door. Can I order a new handle and replace it (how do I take the door apart) - or am i going to need...
Go to RepairClinic.com. They have detailed exploded views of many appliances. This will show you how to replace the door handle or what you need to do..
Jan 16, 2011 | Microwave Ovens
Door Handle snapped off
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 09, 2009 | Maytag MMV5165 Microwave Oven
How to Replace Broken Handle
Sorry but the chat system seems slow and hard to work with.
Page 28 & 29 of the service manual tell you how to remove the door and take it apart to replace the handle.
The service manual is here.
And you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jan 22, 2009 | GE Advantium 120 Convection/Microwave Oven
Broken door handle, have part but can't put it on.
Thats disgusting mate! The doors are either clip together, plastics or if stainless as per photo, it would require opening the case, removal of door then prising off the fascia trim to get to the handles.
I'd ring them back up, that is not a user servicable part as it will bugger the finish trying to separate the doort.
Best of luck
Dec 10, 2008 | Frigidaire FMV157GM Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Broken handle
1) Have to remove the door first; top of the oven there are two screws closest to the door, take those out. and the door should lift out
2) flip the door on the table with the handle side down. starting on the handle side there are three clips (top, middle, and bottom) between the outside casing and inside trim. Using a thin screwdriver gently twist starting at either the top or bottom to pod the two casings apart. work your way around the door.
3) You should see one of the screws that hold the handle on (top) but the bottom screw is under the metal casing so you need to remove the screws around this casing as well to get the other handle screw off.
Once you start you will see it isn't as bad as this sounds. I bought the handle for $40.
It is a shame that this is so cheap and breaks off this easily. Surprisingly we have had ours for at least 6 years before the handle broke and we have 3 girls opening and closing this all the time so I guess I was one of the lucky ones.
Hope this helps and good luck
Nov 20, 2007 | GE Advantium 120 Convection/Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Maytag MMV5207A Microwave Oven Logo
91 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
