Question about Microwave Ovens
Hi, I have a GE counter top microwave (JES1651). It is just over two years old. It has worked flawlessly until two days age when my wife put in her tea cup to reheat it and shut the door. When the timer rang the door wouldn't open. It works fine electrically, all functions work. I thought she may have locked the parental conrol lock accidentally, but that didn't happen. I checked that. Any thoughts on the seemingly locked/jammed door? Thanks, Scott
  • Microwave Ovens Master
  • 9,098 Answers
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find helpful exploded view diagrams here and order parts for less by entering the part number here.
Posted on Aug 21, 2008
GE microwave with error code of PF and won't heat anything up
The "PF" on any appliance indicates a power failure. So if you lost power in a recent storm, this would cause your problem. Pressing the cancel button should clear up your problem, and put you back in business. If not, unplug the unit, plug it back in and try the cancel button again. If trouble persists, your board is probably at fault.
Jul 20, 2014 | GE Microwave Ovens
GE JES1651 microwave stopped woring
it might have short circuited. also check the cable for any break in the line.also take the back of the micro wave and check for any broken wires of pulled out wires.
Mar 10, 2012 | GE JES1651 Microwave Oven
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
Oct 19, 2009 | GE Microwave Ovens
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
Microwave won't heat anything
Yeah, it's time to invest in a new oven. The magnetron tube in yours most likely just finally wore out. It's the source of the microwaves, and like any tube it gets weaker with age and finally just quits altogether. It would cost more for a new magnetron than it would for a new oven these days.
May 15, 2009 | GE Microwave Ovens
What is the wattage on my old microwave
Based on its age and description it is probably 600 watts.
Nov 24, 2008 | Kenmore Microwave Ovens
GE JVM 2050BH001 does not heat but everything else works
hey! you told that everything working in your microwave oven! inside the microwave oven! transformer only producing heat! that transformer only fault in your oven! try to repair or change the transformer!!!!!!!
Sep 29, 2008 | GE JVM2050 Microwave Oven
Kitchenaid model:KHMS105B microwave hood combination
hi alan,
it sounds like the transformer is bad, which makes this easy, time for a new one. 12yrs is a good age for a microwave, average life is about 8-10 yrs!
Mar 21, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
217 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
