Question about Maytag Washing Machines
Washer spins but the water does not spin out - Maytag Washing Machines
  • 706 Answers
Have you cleaned the drain filter of any sediment that may have built up ? That will limit the drain process substantially.. or.. you may have a something lodged inside the pump casing causing it to not pump.. sometimes socks or small garments get caught in there... Also.. check your drain hose for a section that might be pinched or clogged.. Hope these few ideas will get you going again.. Good Luck
Posted on Aug 20, 2008
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Washer will not spin water out
There is a flap inside of the washer that comes up as the washer begins to spin...Just replace that valve and everything should be fine. As long as its spinning and washing you will not need to get a new one :)
Nov 19, 2012 | Washing Machines
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Washer stops during spin cycle
i just relaced my door switch to my washer and it fixed my problem.my washer was doing the same thing as yours
Mar 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
