Question about Toshiba 65H81 65" Rear Projection Television
Convergence Issue- Toshiba 65H81
I have a toshiba 65h81 that the convergence messed up on. I tried using the Touchfocus but got "touchfocus error" We went into the service menu and can't get that red to go any further down. It's only on the bottom left and top right. Took off the screen and it doesn't appear there is any issues with the red gun as we can see it move up and down, etc...
Pretty sure it's the IC chipset based on what most people have said but not exactly sure how easy/difficult of a job it is. From other posts, it looks like chips are between $7-$45.
I can get it fixed for $250...Should I have it fixed at all. Is $250 too much to fix it? If it's easy, how do I do it and does it require any sodering? Is there any other things I should check before going forward?
Also, how many chips would I need, where can I buy them and how difficult is it?
Thanks!
  • Bill Rieth Oct 02, 2008
    Convergence on my 65H81 went south suddenly tonight when I turned on the set. Green is WAY off (2 in) on bottom right. Auto Focus doesn't help.
    I have the same questions: Is it something that can be adjusted or fixed, and at what approximate cost? Or is it a good time to buy a new flat panel?
    Problem Solver:
  • 6 Answers
Guys, I 've replaced my STK's and and it was a 2 and a half hour challenge job for me, in the hope I solve the dreaded red light blinking issue. I have soldered both STK's nice and neat and everything looks in order. One of the problems you might face, is your soldering gun. There are 4 heavy duty pins that keeps each STK in place, and you need a powerful gun to take care of those. The rest of the pins are very small, and you need a different setup for your soldering gun. You also need a suction pen to be able to to take all those pins out.
But it's not a heavy headache, it's just a light one:)
Also the thing is to remember each wire assembly you disconnect and put it back. It takes patience, and you don't wanna destroy them :( For some , that by itself could be a challenge. The Board containing the two STK's is connected to the power board with three neat assemblies....you pry those up from the top suction, and away from the power board.
BUT, as I recall, most of the challenge has to clear that board loose.
I hope this helps.
Nic
Posted on Nov 07, 2008
No Sound
There may be a button on the back of the set
to turn interan speaker on and off
if not then in the sound menu
check that out if that dont do it
get back to me
Nov 27, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba projection tv model 57H82 color convergence is off. tried the TouchFocus and get and error. tried manually but the red will only move up and down. i need it to move left and right.
OK, the problem is one of the STK392-110 convergence amps has died. It is rare that both die at the same time, so either vertical or horizontal will go out, but not both. Also look for an open fusable resistor near said IC.
May 28, 2010 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 convergence problems. TouchFocus
See my solution <http://www.fixya.com/support/t2795690-convergence_off_blue_line_only_vertical>.
You need to get to the service menu--it's been 4 years so go to AVSforum.com to turn off the different guns and get the better pattern.
At your risk: To get into Service mode:
1. Turn your TV on. 2. For X81 or earlier series: Press MUTE on your remote and release. 2. For H80/H81/HX81 series: Press MUTE on your remote and release two times ("Mute" on-screen) 3. Press down MUTE on your remote again and hold. While holding, press the MENU button on your TV set's front panel. 4. Release both buttons. 5. An "S" should appear on your screen. Press MENU again on your TV. 6. Now you're in service mode. Channel Up/Dn - Scrolls through Parameters and Volume Up/Dn - Changes Parameter Value
To get into convergence mode:
Get into Service mode, then Hit '7' to bring up the convergence grid. Buttons 100, 0, and ENT control which gun you want to turn off (if you want to align the red to the green without seeing the blue gun and other variations). 2=up, 8=down, 4=left, 6=right, 3=change gun to converge, 5=converge that point. To exit convergence mode you press 7 once and your screen should look like it's imploding then return to normal and then you press 7 to get back into regular service mode.
I have more info found on the board. -Ken
Jul 31, 2009 | Toshiba 57H82 57" Rear Projection...
TOSHIBA projection television Model 50H12
Good Day, klynn69;
Even though you did not ask a question, I assume you want to know what's wrong. It sounds like the TV has experienced a Convergence Circuit Failure. If you are really handy replace Conv output Amp IC's AND make sure all pico fuses are ok, all jumpers have secure connections OR call for service to An Authorized Service Center and have them come out and give an estimate B4 repair. AVG cost $550.00. Good Luck, big IRISH.
Sep 07, 2008 | Toshiba Televison & Video
Toshiba 65h81
Somewhere along the line you may have missed a cable connection. Recheck to be sure that all of the wires are reconnected. Also, check the +5V line. In the area of the convergence Ics there should be a number of pico fuses. One of those may have opened up.
Keep us posted.
Dan
Jun 09, 2008 | Toshiba 65H81 65" Rear Projection...
Power led blinking
possible.. convergence ic can cause this problem if they become shorted
Apr 16, 2008 | Toshiba 65H81 65" Rear Projection...
65H81 remote and green screen
Yes you can get the service manual at the following link for 10.99 and they will contact you to see if you would like the manual emailed to you. Here is the link.
http://servicemanuals.vstore.ca/
Feb 02, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Horizontal Curvature with convergence problem
DA, convergence circuit has failed, the IC`s and possibly a couple of support resistors need to be replaced, your right about it being a good set, 6 years is about average for convergence IC`s, call your local shops for a few estimates and get it fixed, it will run for a lot longer than 6 years, hope this is the advice your looking for, e-mail me if you have more questions, BMW Rider
Dec 10, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 65" Rear Projection Television Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
